What Is Wrong With This Engine - Video
13 replies to this topic
  • 2,348 Thanks
  • 1,502 posts
Posted November 22, 2014 - 10:02 AM
Someone just posted a video on Kijiji asking why the exhaust on his snowblower gets red hot & blows flames.  Any ideas? The problem shows up in the last few seconds of the video
http://www.kijiji.ca...gationFlag=true
  • classic said thank you
#2 lyall OFFLINE
lyall
  • 2,227 Thanks
  • 1,593 posts
Posted November 22, 2014 - 10:14 AM
exhaust valve not closing and/or too much gas
  • GTTinkerer and New.Canadian.DB.Owner have said thanks
#3 Reverend Blair OFFLINE
Reverend Blair
  • 501 Thanks
  • 952 posts
Posted November 22, 2014 - 10:33 AM
Definitely getting gas in there somehow. Seems to run okay though.  I'd check the carb first.
#4 Cvans ONLINE
  • 7,288 Thanks
  • 6,377 posts
Posted November 22, 2014 - 10:41 AM
Looks like the Carb was bouncing around, the mounting bolts are loose?
#5 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
sheer pin has timming off a few degrees.
#6 hamman OFFLINE
hamman
    Homelite Owner Extraordinaire
  • 6,597 Thanks
  • 2,908 posts
Posted November 22, 2014 - 10:54 AM
Might be shear pin / key or carb is out of adjustment. JM2CW.        Roger
  • Auburn David said thank you
#7 classic ONLINE
classic
  • 5,631 Thanks
  • 2,345 posts
Posted November 22, 2014 - 05:04 PM
Go to youtube and search diesel generator first and last start. The guy seems to think there's a problem with it. I would post the link, but I haven't tried doing that yet.
#8 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted November 22, 2014 - 05:05 PM
Yea I saw that one..it was pretty sad to watch that..
#9 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted November 22, 2014 - 05:07 PM
#10 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted November 22, 2014 - 05:33 PM
On Youtube Videos all you have to do is post the URL and it will post your video :) (EG..in place of a comment just post https://www. youtube. com/watch?v=gwNfhEUqfuY without the spaces of course)
#11 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted November 22, 2014 - 05:54 PM
Muffler is held on by one bolt, air is being sucked in and burning the extra fuel from a not properly tuned carb that also looked a bit loose to me too.
#12 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted November 23, 2014 - 06:36 AM
I had the exact same thing happen to mine!! It fixed it self when it turned red hot and blew out the mouse nest in it. That muffler may have been defective internally that is why the engine wouldn't run smooth and was throwing flames. If he would have taken it off he would have seen the Genny run smoothly and handle a load.
  • karel said thank you
#13 MH81 OFFLINE
  • 29,978 Thanks
Posted November 23, 2014 - 08:42 AM
On the original question, I would say the carb had to be turned up so much to compensate for the air sucking in that there is significant unburied fuel in the muffler. I wouldnt be surprised if he has the choke on.
Add to that the one bolt mounting method and the fact that it probably needs a ring and valve job from having the break in oil in there still... Well, you know...
#14 DH1 ONLINE
DH1
    Electric Tractors
  • 5,415 Thanks
  • 5,616 posts
Posted November 23, 2014 - 09:31 AM
It seems to run OK, missing 1 bolt in the muffler, exhaust leaks out there that's why it gets red with flames.
Looks like he shuts it off by closing the choke.
Lots of fuel, hot muffler, maybe some air getting the missing bolt hole = flames.
