Ford Ranger 4.0 Liter Upper Rad Hose Collapsing
65 replies to this topic
#46 MH81 OFFLINE
Posted November 27, 2014 - 07:59 PM
Man, that has to be one of the weirdest cause/symptoms I've seen in a long time.
Thanks for the follow up.
  • massey driver said thank you
#47 toppop52 ONLINE
toppop52
  • 5,265 Thanks
  • 4,762 posts
Posted November 27, 2014 - 10:23 PM
It's not weird, it's exactly what I expected from the beginning. The only way to get vacuum where there should be pressure, is a vacuum leak. That's why I kept referring back to the gaskets at the intake and head. We see it several times a year. Glad you found it and it wasn't too bad.
#48 toomanytoys84 ONLINE
toomanytoys84
    Aaron
  • 9,887 Thanks
  • 5,962 posts
Posted November 27, 2014 - 10:29 PM
I see the problem and the reasoning. Personally I have never had an intake gasket fail without losing antifreeze or seeing tons of steam out of the exhaust.
my ex wife had a mid 90s Monte Carlo with a 3.4 v6. It blew 3 intake manifold gaskets in a short time. Always loss of antifreeze and steaming out the exhaust like crazy.
#49 toppop52 ONLINE
toppop52
  • 5,265 Thanks
  • 4,762 posts
Posted November 28, 2014 - 12:08 PM
He had to be losing coolant, that's why the gaskets looked like they did with all the crud around the edges of the intake. But you can have a very small leak and it will still set up a vacuum that will eventually collapse the hose. The 3.4/3.1 is another known intake/intake gasket failure prone motor, as is the 3.8 GM and the 4.2 and 4.6 Ford. Depends on the year and application.
  • toomanytoys84 said thank you
#50 toomanytoys84 ONLINE
toomanytoys84
    Aaron
  • 9,887 Thanks
  • 5,962 posts
Posted November 28, 2014 - 01:02 PM
The 3.4/3.1 is another.....
I got very good at changing that gasket out. I changed the 3rd one and we sold it before there was a 4th! I got so tired of it every year. I could tell as soon as she started the car and took off. It would look like a smoke grenade was set off behind the car.
GM quality right there.
I had a 3.1 in a buick regal. Never a hiccup and had a 3.8 SS in a Rivera. Never a problem. But that 3.4 was junk.
Edited by toomanytoys84, November 28, 2014 - 01:03 PM.
  • Sawdust and toppop52 have said thanks
#51 toppop52 ONLINE
toppop52
  • 5,265 Thanks
  • 4,762 posts
Posted November 29, 2014 - 10:52 AM
If you had replaced the intake with an aftermarket like Dorman, it would have cured it.
#52 dodge trucker ONLINE
dodge trucker
  • 2,433 Thanks
  • 3,123 posts
Posted November 29, 2014 - 11:48 AM
and someone said something of the switch of auto parts to Chinese sourced...  no it would not have solved it/ at least not long term
  • toppop52 said thank you
#53 toppop52 ONLINE
toppop52
  • 5,265 Thanks
  • 4,762 posts
Posted November 30, 2014 - 10:10 AM
In our shop, we have replaced a few dozen intakes on various engines, some with factory updated units, some with aftermarket, never, ever had a return, some as far back as the late 90's, that seems like a fix to me. But hey, I'm just a service manager with 44 years in the business.  By the way, a lot of the GM 60° V6 engines are built entirely in China.
Edited by toppop52, November 30, 2014 - 10:16 AM.
#54 toomanytoys84 ONLINE
toomanytoys84
    Aaron
  • 9,887 Thanks
  • 5,962 posts
Posted November 30, 2014 - 01:59 PM
It honestly never occurred to me to change the whole manifold.  cost 45 bucks for me to fix and a few hours.
The first time I took it to a gm garage to fix it they said 900 for the repair. I took it home.
#55 DougT OFFLINE
DougT
    Dog Approved
  • 6,926 Thanks
  • 4,994 posts
Posted November 30, 2014 - 02:07 PM
I don't think I've ever seen a Dorman intake for the 3.4 engine. My experience has been that the problems started happening when they went to the plastic gaskets with the rubber lip. I'm a firm believer in the Fel-Pro "no leak" sets for these engines that use the steel with the heavy rubber attached. Never had a come back on one of those and I've even re-used them a couple times when necessary. Of course that set is in the 100 dollar range compared to 40 for the plastic ones.
#56 toppop52 ONLINE
toppop52
  • 5,265 Thanks
  • 4,762 posts
Posted December 01, 2014 - 08:35 AM
I was actually answering the person that had fixed theirs several times, if I didn't have the experience I do, I'd assume that replacing the gaskets would be a permanent fix, and sometimes it is. I never use anything but Fel Pro Perma Dri gaskets. Near zero failure rate with them.
And just as a reference, here is a link to a Dorman 3.4 intake manifold...http://www.ebay.com/...8f0f38f&vxp=mtr
#57 toppop52 ONLINE
toppop52
  • 5,265 Thanks
  • 4,762 posts
Posted December 01, 2014 - 08:38 AM
To be fair, far more of the plastic intakes fail, than do aluminum, but the 3.4 is one known to have problems with the aluminum intake.
#58 TAHOE OFFLINE
TAHOE
  • 7,975 Thanks
  • 5,675 posts
Posted December 01, 2014 - 10:17 AM
 as is the 3.8 GM ...
At 135K on the Fireturd's 3.8 and no issues with intake. Now the pan gasket though..... :wallbanging:
I knew I should've changed it before I did the engine swap, but was in a rush
#59 Alc ONLINE
  • 6,884 Thanks
  • 7,459 posts
Posted December 02, 2014 - 06:34 AM
Wouldn't the radiator cap open under vacuum when the upper hose was collapsing ?  Pulling what was in the overflow tank ?
#60 AfterShock95 OFFLINE
AfterShock95
  • 420 Thanks
  • 365 posts
Posted December 02, 2014 - 07:01 AM
My 98 ranger with a 4.0 did the samething after I bought it it was the over flow line got pinched under the air box and couldn't suck anything back in to the raditor
