Looking For A Gp Flux Core Recommendation
10 replies to this topic
  • 2,331 Thanks
  • 1,498 posts
Posted November 21, 2014 - 07:32 PM
I am new to welding & have been using NR-211 flux core wire because that's what came with the welder.  I do mostly mild steel (1018) & some thin sheet metal work.  I am out & need to buy more.  What is a good general purpose flux core wire?
#2 tater195 ONLINE
tater195
  • 2,200 Thanks
  • 1,413 posts
Posted November 21, 2014 - 07:35 PM
I use the forney or lincoln .035, which ever is in stock at the farm store. 10# spool is around $75
#3 dodge trucker ONLINE
dodge trucker
  • 2,453 Thanks
  • 3,135 posts
Posted November 21, 2014 - 10:07 PM
menards by me had some .035 flux core on the clearance rack the last few times I'd been in there but I run gas with solid wire, "gasless" does me no good.... but I have  a"big" Miller MIG
#4 Jazz OFFLINE
Jazz
  • 2,401 Thanks
  • 1,446 posts
Posted November 21, 2014 - 11:04 PM
Buy  a quality wire from your local welding house i.e.: liquid air or whoever is in your area. If you are using flux core buy quality over quantity ,  there is a difference. JMHO
#5 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted November 21, 2014 - 11:19 PM
  The OP probably doesn't have gas capability, but when I bought my MM 175 I tried the 1 lb roll of flux core that came w/ it and switched to solid wire w/ C25. That flux core is still on the shelf under the mig. If I need to weld something 1/4" I crank it all the way and burn it in good. Anything thicker the old Thunderbolt stick machine comes into play. I don't fret about burning holes w/ the mig. With manual pulse weld you can fill any hole.
                                     Mike
  • GTTinkerer and New.Canadian.DB.Owner have said thanks
#6 Oldford OFFLINE
Oldford
  • 1,134 Thanks
  • 786 posts
Posted November 22, 2014 - 02:18 AM
If you're doing sheet metal you may consider getting 2 spools, .024 for thin stuff, and .035 for thicker stuff.  Different size tips are pretty cheap too.  Forney does fine for me, which seems to be the basic hardware/auto parts store brand.  I prefer small spools for storage purposes as i don't weld that much.
#7 New.Canadian.DB.Owner OFFLINE
  • 2,331 Thanks
  • 1,498 posts
Posted November 22, 2014 - 09:31 AM
Thanks for all the input, but I think I may not have been as clear with my question as I could have been:  Is NR211 the best flux core wire for the job or is there a better rating, like E71T-11?
#8 Jazz OFFLINE
Jazz
  • 2,401 Thanks
  • 1,446 posts
Posted November 22, 2014 - 09:55 AM
I am no expert but I think E71T-11 is a designation for a stick electrode..The 7 referring to 70,000 lbs tensile strength.  I rarely use flux core as most of my welding is body work where shielded welding is so much cleaner. I do enough of this type of welding to have gas on my welder.   You may source some wire that is softer(easier for grinding)
#9 coldone OFFLINE
coldone
  • 1,651 Thanks
  • 1,679 posts
Posted November 22, 2014 - 05:30 PM
Cant make a suggestion on the numbers, but I started with Hobart flux core. One member here suggested switching to lincoln wire. It was a world of difference. I dont buy Hobart anymore.
#10 dodge trucker ONLINE
dodge trucker
  • 2,453 Thanks
  • 3,135 posts
Posted November 23, 2014 - 09:37 AM
no that isn't a stick designation. it is a wire designation. I do not remember the "code" about what all the numbers mean (I do know it more so for stick)  but I use E (or ER)-70S6 in my MIG which is solid core wire.  Yes, in MIG wire "code" I do know that the E is "electric arc" and the "70" is 70K tensile strength.  I remember them saying when I bought my 1st roll that if I tended to weld on "dirty" metal, that the "ER" was better than just "E" They do sell E-70S6 which is for "cleaner" metal... and that designation does not have anything to do with wire thickness. usually that is indicated after another dash after the "S6"   either -23, or -30, or (what I normally run), -35.
Even though Mig isn't "stick" welding it is still a type of "electric arc" welding...so yes the "E" at the beginning of the "wire code" still applies.
#11 dodge trucker ONLINE
dodge trucker
  • 2,453 Thanks
  • 3,135 posts
Posted November 23, 2014 - 09:40 AM
and regarding "Hobart" wire... I have heard that before but Hobart and Miller = same company. (Lincoln is "the other guys")
I think it may have more to do with how "fresh" a spool you run, if it sits out alot and draws moisture/gets any rust on the wire that will mess with your welds. maybe the Hobart wire has sat in a warehouse longer?
