Case 446 brake
17 replies to this topic
#1 JoshBrown OFFLINE
JoshBrown
  • 20 Thanks
  • 277 posts
Posted February 23, 2011 - 09:20 PM
I was wondering how the brakes on the case is suppose to work I assumed that when you hit the brake it tightened the band around the drum and slows you down. I guess that is what happens on my tractor except for when you step on the brakes the tractor goes into reverse. I don't think that this is normal any ideas?
Also the brake drum and band setup looks pretty crappy I don't think fully functional that it would stop very good, is there another brake systems out there that is commonly retrofitted to the case?
#2 olcowhand ONLINE
  • 43,118 Thanks
  • 31,998 posts
Posted February 23, 2011 - 09:22 PM
A brake linkage must be hitting the directional/speed valve linkage somehow. The valve is down low, so something must be hitting it.
#3 JoshBrown OFFLINE
JoshBrown
  • 20 Thanks
  • 277 posts
Posted February 23, 2011 - 09:41 PM
I will have to check that I didn't think that it was normal. Did you see the video Daniel I got her running like a top.
#4 olcowhand ONLINE
  • 43,118 Thanks
  • 31,998 posts
Posted February 23, 2011 - 09:45 PM
Yep, she sounded great! BTW...the spark plugs are the washer type?
#5 olcowhand ONLINE
  • 43,118 Thanks
  • 31,998 posts
Posted February 23, 2011 - 09:49 PM
If it has heads that use washer sealed plugs, then you need Champion RH18Y...or Onan part #167-0298
#6 JoshBrown OFFLINE
JoshBrown
  • 20 Thanks
  • 277 posts
Posted February 23, 2011 - 09:51 PM
Ok like I said it has two different ones in it I didn't know if they took certain ones like a # I could just go and say I need "these plugs" I had a guy look them up at napa but the ones he gave me were not even close.
#7 JoshBrown OFFLINE
JoshBrown
  • 20 Thanks
  • 277 posts
Posted February 23, 2011 - 09:52 PM
That sounds good They have washers on them. I will try those
#8 JoshBrown OFFLINE
JoshBrown
  • 20 Thanks
  • 277 posts
Posted February 23, 2011 - 09:55 PM
I will take the ones they gave me back and get a set of Champion RH18Y.
#9 JoshBrown OFFLINE
JoshBrown
  • 20 Thanks
  • 277 posts
Posted February 23, 2011 - 10:26 PM
I will also have to check the linkages and make sure nothing is hitting. Does anybody know if everything is working like it is suppose and band has good brake material on it if they work good, can they stop you on a hill ect.?
#10 bhts OFFLINE
bhts
  • 1,483 Thanks
  • 2,170 posts
Posted February 23, 2011 - 10:50 PM
I think when you hit the brake it should move the handle to the nuetral postion.So if it is going in reverse then check the adjusment and as dan said make sure it is not hitting something.And yes when the brake is pushed and all things are adjusted proper it will hold on a hill just fine.
#11 cp7 OFFLINE
cp7
  • 59 Thanks
  • 148 posts
Posted February 24, 2011 - 12:09 AM
The brake is only a parking brake. As you noticed it isn't very substantial and definitely not enough to overcome the hydraulic drive system. That's why they designed it to return to neutral which is what actually stops the tractor when the brake is applied and it sounds like yours needs to be adjusted. The adjustment procedure is posted in the Yahoo Case groups files.
Edited by cp7, February 24, 2011 - 12:15 AM.
#12 JoshBrown OFFLINE
JoshBrown
  • 20 Thanks
  • 277 posts
Posted February 24, 2011 - 08:39 AM
Ok thanks guys I will check it out it makes since now that when you apply the brakes that it has to put the drive back into neutral I would guess that it is pushing the drive too far and into reverse.
#13 olcowhand ONLINE
  • 43,118 Thanks
  • 31,998 posts
Posted February 24, 2011 - 09:37 AM
Forgot about that! Yep, just needs adjusting. Thanks for catching that cp7! But to add, this tractor has no holding valve, so the brake does have to do stopping chores at times.
#14 JoshBrown OFFLINE
JoshBrown
  • 20 Thanks
  • 277 posts
Posted February 24, 2011 - 03:39 PM
Yeah my place is pretty flat but I would fell better if I get some kind of a brake in working order. Just in case!!! I'll check it out. Also wondering if anyone has ever put a different (better) kind of brake system on a case?
#15 jscam OFFLINE
jscam
  • 21 Thanks
  • 69 posts
Posted March 04, 2011 - 07:16 AM
Yes, I have seen pics of a disc brake conversion a guy came up with.......it looks great.......it's in another site, not sure if I should post that here. Email me and I'll do my best to forward it to you.
