Looking At My First Ariens And Have Questions
5 replies to this topic
#1 cpg OFFLINE
cpg
  • 251 Thanks
  • 151 posts
Posted November 19, 2014 - 07:55 PM
Hey all. I have the opportunity at an Ariens that I hope to pick up. From my research and the picture sent I think it is an S-10G; I know the G for sure as it clearly says gear on the side decal. It has a nice big snowblower that I would love to use in my driveway and the owner said it drove and threw snow great until the engine "grenaded" which doesn't sound very good. He said it has a 10hp Kohler. If anyone has one of these does it have the 10hp K series Kohler? It looks like it in the pics I've found and I'm hoping its true because I just so happen to have an extra K241 10hp sitting on my bench.
Thanks
  • A.C.T. said thank you
#2 Cat385B OFFLINE
    HAZMAT CAT
  • 14,456 Thanks
  • 10,184 posts
Posted November 19, 2014 - 08:00 PM
K241 was the original. I can't find the shaft size/length.
#3 cpg OFFLINE
cpg
  • 251 Thanks
  • 151 posts
Posted November 19, 2014 - 08:05 PM
Ok thanks, the K241 I have was originally in a Wheelhorse if that helps at all.
#4 shorty ONLINE
shorty
  • 5,921 Thanks
  • 5,452 posts
Posted November 19, 2014 - 08:44 PM
The drive shaft bolts on the flywheel side. And the front pto comes off the shaft side. Using a electric clutch.
#5 cpg OFFLINE
cpg
  • 251 Thanks
  • 151 posts
Posted November 19, 2014 - 08:54 PM
Ok, sounds like the engine layout is similar to my Cub Cadet. Even if I have to swap flywheels or whatever for mounting purposes I at least know that I basically have a good long block to put in it. Thanks for the info. If I do manage to pick it up I will make sure to gets some pics.
#6 boyscout862 ONLINE
  • 13,690 Thanks
  • 9,475 posts
Posted November 20, 2014 - 09:41 AM
Check our Manuals Section for more info. Good Luck, Rick
