Hi. I am going to pick up a '67 424 later this week but am concerned it won't roll up my ramps due to a broken flange bearing. I probably need to be prepared to fix it first but have never fooled with one and unsure what it will require. Do you think the bearing went inside the rim such that I can remove it and reinstall? Where can i get a bearing if I need a new one?
It is also missing a tie rod end clip so the other tire won't steer. I figure I can use a hose clamp or something to hold the tie rod end onto the ball to at leat get it home and around the yard?
