Tundra Troubles
18 replies to this topic
#1 skyrydr2 OFFLINE
  • 3,886 Thanks
  • 3,410 posts
Posted November 19, 2014 - 04:55 AM
Anyone here ever do a heater core on a toylet odor tundra? Last few days I was wondering why my mouth was tasting something funny on the ride to work... Then I got it good this am ... Heater core. Antifreeze taste that's what it was.
This thing is starting to nickel and dime me to death... NEVER EVER AGAIN.... I HATE WORKING ON THEM but also I'm also to dang cheap to pay ,only to have it not done correctly....
Looks like ill be a toylet odor tech this weekend.... Ooooooh soooooooo not happy!!! Especially when Isee what the nnational average of this job costs!!! $750-$950 .....
#2 KennyP ONLINE
  • 38,299 Thanks
  • 45,895 posts
Posted November 19, 2014 - 06:16 AM
Sorry to hear of the issues! Can't give you any help on this!
#3 Oldford OFFLINE
Oldford
  • 1,134 Thanks
  • 786 posts
Posted November 19, 2014 - 06:21 AM
They get clogged with scale, If it's not leaking you might be able to flush it out.  If you can disconnect the two hoses going into the core, use a cut-off garden hose with a plastic barb stuck into the end.  Catch the green stuff in a pan and recycle it.  I use water and compressed air in both directions until it runs clear.  Do it in a place where pets don't go cause you can't catch every drop.  Have done several vehicles like this it brings back the heat, gets rid of the smell, saves the heater core.  good luck
#4 Alc ONLINE
  • 6,884 Thanks
  • 7,459 posts
Posted November 19, 2014 - 06:39 AM
Have you looked for any youtube videos on your Tundra ?    I'm a firm believer after doing some work on  6.0 Ford , following the Snap-On Shop Keys instruction  ( which are copied from the Ford shop manual )  taking off the stuff they told me  and then watched a guy on Youtube  do it SO much quicker by just a few different steps here and there  !!!
  • Cvans said thank you
#5 EconChuck OFFLINE
EconChuck
  • 252 Thanks
  • 289 posts
Posted November 19, 2014 - 09:23 AM
Hi,
What year is your Tundra and how many miles?
I have a 2007 and love it, 127,xxx miles and counting. Fortunately when I bought it the dealer included an unlimited powertrain warrantee(gotta pay a deductible for each repair). That helped to make the decision to drive it for a long time.
Recently had to replace the water pump, told by dealer a ~$700 repair and just paid my deductible.
Good luck.
Chuck
#6 toomanytoys84 ONLINE
toomanytoys84
    Aaron
  • 9,882 Thanks
  • 5,960 posts
Posted November 19, 2014 - 09:41 AM
Hi,
Good luck.
Chuck
I got the same unlimited powertrain on my Tacoma.  Good piece of mind.
What year is your truck?  Every heater core I have messed with was a PITA.  1997 F150 4.2(the crappy 6)  I had to remove almost the whole dash.
#7 Gtractor ONLINE
Gtractor
    G-agressive tractor
  • 9,316 Thanks
  • 4,952 posts
Posted November 19, 2014 - 10:31 AM
Last heater core I had to work on was on a 1952 Chevy pickup.  It gave me no trouble,  was easy to get to and I had it out in a jiffy.
:poke:   :wave:
I should probably get a point just for rubbing that one in.........      :anvil_drop:
  • LilysDad and Bill 76 have said thanks
#8 WNYTractorTinkerer OFFLINE
WNYTractorTinkerer
    Tinker Master
  • 10,457 Thanks
  • 5,764 posts
Posted November 19, 2014 - 10:45 AM
Things have changed quite a bit since 1952 though..  More and more BS to change them out now!  If you taste A/F in the cab the core is leaking and DO NOT FLUSH IT!
Swap the core out.. I've never worked on a Tundra but follow the heater lines to where it is..  It's never fun.. I liked the older vehicles that had a heater box in front of the firewall.  They were EASY!
Just take your time and remove the heater box plenum (The Glove box needs to be removed first to gain access).  Take your time and don't force/break things..
Good Luck!
Look HERE
#9 Kmac1 OFFLINE
Kmac1
  • 522 Thanks
  • 221 posts
Posted November 19, 2014 - 11:20 AM
Weren't the heater cores in 1952 a dealer installed option?
#10 Kmac1 OFFLINE
Kmac1
  • 522 Thanks
  • 221 posts
Posted November 19, 2014 - 11:27 AM
If you smell it in the cab it is leaking in the heater box, can you feel the carpet to see if it is damp where it is running down the firewall.  You shouldn't have to pull the whole dash,  just loosen the right side enough to remove the heater box.  It will be tight getting the box out and you may need a helper to hold the dash out as you remove the heater box.  When you get the box out there are some 1/4-7mm head screws you will take out to access the heater core.  As far as step by step instructions I can not provide those.  Plan on spending 4-6 hours on the R and R.  willie
  • MH81 and HDWildBill have said thanks
#11 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,294 Thanks
  • 9,777 posts
Posted November 19, 2014 - 12:08 PM
How about the early 60s Chevy trucks. They had the box on the firewall . . . down behind the fender well!  I knew a guy that had a beater 73 Pontiac he drove to work. When the heater fan went out, he torched a hole in the fender to get at it. :D
Edited by LilysDad, November 19, 2014 - 12:09 PM.
  • WNYTractorTinkerer and Bill 76 have said thanks
#12 Jazz OFFLINE
Jazz
  • 2,392 Thanks
  • 1,440 posts
Posted November 19, 2014 - 12:18 PM
I would reference a repair manual as they usually offer a solution to removing heater core that may not be obvious to owner.. In my experience it is never something so simple as a loose hose connection when there is coolant leak in cab
#13 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,989 Thanks
  • 4,410 posts
Posted November 19, 2014 - 01:34 PM
My experience with heater cores has me firmly beleaving that the car designer started with the heater core and built the rest of the car around it...... Pontiac Sunfire as an example.
  • Alc, LilysDad and Sawdust have said thanks
#14 skyrydr2 OFFLINE
  • 3,886 Thanks
  • 3,410 posts
Posted November 19, 2014 - 03:41 PM
Thanks guys for all the insite LOL . the clunker is an 02 with 170K on it. This on has to have the dash and support removed to get to the box. It has a/c too... I hope I don't need to discharge it..... If so... Stop leak here we come!! And down the road this truck will go! 15 years of working as an auto tech has me completely hating it!
What stinks is I need a truck, but have so few choices. The new GMs are gutless, Fords are ugly and un-comfortable , Toyotas are fuel pigs as are Nissans too...only real choice is a Ram but they have girly suspension( probably really rugged but my brothers would bust my you know whats if i got a truck with coils lol) so whats left??? and I need a crewcab too.... Damit GM get with it!!! I need a half ton diesel!!!!!!
#15 dodge trucker ONLINE
dodge trucker
  • 2,432 Thanks
  • 3,122 posts
Posted November 19, 2014 - 06:26 PM
bust your you know whats to buy a Ram?? I'd b bustin chops on anyone that buys a Toyota or Nissan for sure...
  • Sawdust said thank you
