What Is Wrong With This Picture...
11 replies to this topic
#1 twostep OFFLINE
twostep
    Rockstar
  • 1,985 Thanks
  • 2,536 posts
Posted November 18, 2014 - 11:49 AM
http://www.ebay.com/...=item2a473a7f3a
  • Gtractor, MH81 and IamSherwood have said thanks
#2 Gtractor ONLINE
Gtractor
    G-agressive tractor
  • 9,327 Thanks
  • 4,953 posts
Posted November 18, 2014 - 12:12 PM
gonna need a pretty good spacer.......and therefore a longer actuator arm.......
Edited by Gtractor, November 18, 2014 - 12:12 PM.
  • twostep and superaben have said thanks
#3 Bud W OFFLINE
Bud W
  • 326 Thanks
  • 303 posts
Posted November 18, 2014 - 12:25 PM
It looks like someone was "working" on it and got the bottom rotated 90°.
  • rustyoldjunk and MH81 have said thanks
#4 chris m OFFLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted November 18, 2014 - 12:27 PM
I wonder if someone put it in wrong and the cam bent the arm straight??
I guess you could mount a handle to it and work it manually :D
  • rustyoldjunk said thank you
#5 twostep OFFLINE
twostep
    Rockstar
  • 1,985 Thanks
  • 2,536 posts
Posted November 18, 2014 - 12:55 PM
Are pumps for Kohler Magnum engines turned like this?
  • 1oldbuzz said thank you
#6 1oldbuzz OFFLINE
1oldbuzz
  • 564 Thanks
  • 448 posts
Posted November 18, 2014 - 03:24 PM
I think so
#7 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted November 18, 2014 - 03:58 PM
I thought Magnum blocks were the same as K blocks??
#8 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted November 18, 2014 - 07:00 PM
No.  Someone has taken it apart and forgot how it went together.  :(
Some are different than the comparable model K series pumps, but not significantly.  Its all in the actuating arm.
Ben W.
#9 olcowhand ONLINE
  • 41,146 Thanks
  • 31,416 posts
Posted November 18, 2014 - 07:58 PM
As said, no Kohler block would allow bolt up of a pump oriented like that one.  Been monkeyed with so it's one to avoid for sure!
#10 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,295 Thanks
  • 9,779 posts
Posted November 18, 2014 - 08:04 PM
Was it rebuilt? If so, just turn the part around.
#11 IamSherwood OFFLINE
  • 8,391 Thanks
Posted November 18, 2014 - 09:44 PM
Maybe he had in mind to use his die grinder, and grind a cavity into the block
for the fitting, but then discovered that his compressor is now sucking, after
he rebuilt it.
#12 diesel nut ONLINE
diesel nut
  • 700 Thanks
  • 427 posts
Posted November 18, 2014 - 10:13 PM
That's off of a kt or magnum twin engine.             Stewart
  • twostep said thank you
