Troy-Bilt Engine
19 replies to this topic
#16 j p smith OFFLINE
j p smith
  • 21 Thanks
  • 28 posts
Posted November 20, 2014 - 08:13 AM
I looked at the number on the frame last night and I can not make out the first or last numbers, the number stamps were not centered where I can read them. it looks to be that there are 7 numbers, the middle 5 numbers are 19724. The first number looks like it could be an 8 and the last might be a 7. Thanks
#17 j p smith OFFLINE
j p smith
  • 21 Thanks
  • 28 posts
Posted December 16, 2014 - 05:20 PM
Have not been able to find out any addional info on the Troy/Briggs engine. I think I am going to go ahead and tear it down,see what it needs to rebuild it. Thanks for the replies.
#18 TAHOE OFFLINE
TAHOE
  • 7,814 Thanks
  • 5,612 posts
Posted December 17, 2014 - 08:24 AM
Here are the pony serial numbers.
I am betting that "8" is an S and yours drops in there early 1983
Jul - 1976 P10001
Jan - 1977 P12184
Jul - 1977 P17239
Jan - 1978 P21736
Jul - 1978 P27504
Jan - 1979 P33557
Jul - 1979 P40287
Jan - 1980 P48773
Jul - 1980 P58906
Jan - 1981 P68034
Jul - 1981 P80423
Jan - 1982 P89466
May - 1982 S101843 Pony III
Jul - 1982 S105606
Jan - 1983 S117319
Jul - 1983 S129028
  • j p smith said thank you
#19 Bruce Dorsi OFFLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 3,914 Thanks
  • 2,451 posts
Posted December 17, 2014 - 09:37 AM
If the cylinder is scored, look for a different engine.  (More info below.)
If the cylinder bore is not scored, check the piston.  ....If that is OK, your engine is probably worth repairing and installing new piston rings.
Most often, when these B&S engines would seize, it was where the connecting rod attached to the crankshaft. .....This can be repaired 90% of the time.  ....You will need to replace the connecting rod.  ....When there is not enough oil, the aluminum material from the connecting rod gets deposited onto the crankshaft journal due to friction.  ....The aluminum on the crankshaft can be removed by using emery cloth or muriatic acid (Home Depot, Lowe's, masonry supply houses, some hardware stores, swimming pool supply, etc).   .....If you use abrasives, you only want to remove the aluminum.  .....Do not score the crankshaft.  .....Use some fine "Scotchbrite" to polish the crankshaft journal.
If the crankshaft is seized in the cylinder block, you may, or may not, be able to repair the damage.  ...Sometimes, it's not as bad as it seems.
If your engine is not worth repairing, look for a good-running used 5hp B&S with model #130202.  ...These engines were used on many types of equipment, but did not have the extended camshaft.   .....Make sure the crankshaft is the same length as on your old engine.  (If your old crankshaft is good, but the cylinder block is shot, you can re-use your crank.) .....Use your original camshaft and side-cover on the "new" engine.  ....Check the valve clearances, and you should be OK.
#20 j p smith OFFLINE
j p smith
  • 21 Thanks
  • 28 posts
Posted December 22, 2014 - 12:54 PM
Thank you Tahoe.
Hey Bruce. Thanks, this makes the most sense. Thanks again. I will get into the engine next week.
