Yt16H Ford Trans Fluid ?
6 replies to this topic
#1 propane1 ONLINE
propane1
  • 8,708 Thanks
  • 4,121 posts
Posted November 18, 2014 - 08:23 AM
Going to fix a leak in the rear end hydro. On the tractor is says to use 20W oil. So when I refill it what can I use. Can't buy 20W oil here any where. What do you suggest ?? Noel
#2 KennyP ONLINE
  • 38,221 Thanks
  • 45,860 posts
Posted November 18, 2014 - 08:30 AM
I just looked in the manual and that's what it says also. I wonder if a hydraulic/transmission oil would work okay?
  • propane1 said thank you
#3 Sprint 6 ONLINE
Sprint 6
  • 237 Thanks
  • 297 posts
Posted November 18, 2014 - 08:37 AM
Call an auto parts store such as Napa who might have someone knowledgeable at the counter.  Ask about the different hydraulic oils available and what their weights are.  I would shy away from using motor oil now because zinc has almost been universally removed from motor oil in the 30 odd years since these machines where built.  Zinc would be a major anti-wear component needed for the pump and gears.  I would suspect you could probably use some type of universal trans fluid for farm tractors.  I believe Hytran has a weight somewhere in the 10w30 range, I went through this with my Oliver hydraulics a few years ago.  It originally spec'd motor oil also, but oil had changed a lot since '57.  I used a universal hytran in it from a farm store without problems.
  • KennyP and propane1 have said thanks
#4 KennyP ONLINE
  • 38,221 Thanks
  • 45,860 posts
Posted November 18, 2014 - 08:56 AM
That's what I was thinking of!
#5 skyrydr2 OFFLINE
  • 3,886 Thanks
  • 3,410 posts
Posted November 18, 2014 - 12:02 PM
AW32 hydraulic oil will do a bang up job for you.
#6 propane1 ONLINE
propane1
  • 8,708 Thanks
  • 4,121 posts
Posted November 18, 2014 - 04:50 PM
Any body know about how much to put in ?  Noel
#7 fxdb96 OFFLINE
fxdb96
  • 118 Thanks
  • 105 posts
Posted November 19, 2014 - 12:24 PM
I use FORD TYPE F in my GT14
