Lift Handle 1250
6 replies to this topic
#1 buicfrank OFFLINE
buicfrank
  • 4 Thanks
  • 11 posts
Posted November 17, 2014 - 07:17 PM
While cruising around the yard on my 1250 hydrostatic the lift arm mechanism fell apart. This raises the lawn cutting deck by fluid. (I think) Does anyone have a picture on how it goes together? Short L shaped lever rather than the long manual lever.  Thanks Frank
#2 dodge trucker ONLINE
dodge trucker
  • 2,453 Thanks
  • 3,133 posts
Posted November 17, 2014 - 08:17 PM
is this a 1250 cub cadet? that's the only "1250" tractor I am familiar with... Cub's "Quietline" series  and at that its been a few years  since I messed with one...
#3 buicfrank OFFLINE
buicfrank
  • 4 Thanks
  • 11 posts
Posted November 17, 2014 - 09:07 PM
yes
#4 Sawdust ONLINE
Sawdust
  • 5,677 Thanks
  • 3,379 posts
Posted November 17, 2014 - 10:04 PM
I have a 1250 CC also. Check out the manuals section of the forum. You can download three free a day. Hope this helps.
 http://gardentractor...1650-operators/
#5 buicfrank OFFLINE
buicfrank
  • 4 Thanks
  • 11 posts
Posted November 17, 2014 - 10:19 PM
The manual does not show assembly instructions. I will check with the dealer tomorrow.  Thank you for the help.  Frank
#6 buicfrank OFFLINE
buicfrank
  • 4 Thanks
  • 11 posts
Posted May 21, 2015 - 04:53 PM
Does anyone have a lift handle for this 1250 tractor. Mine cracked where the hole was drilled.  They are extinct at the dealers.
thanks Frank
#7 dthomp17 ONLINE
dthomp17
  • 587 Thanks
  • 472 posts
Posted June 02, 2015 - 07:52 PM
Frank, you could probably make a lift handle if you can get the right diameter steel rod.  The trick is getting the right diameter hole drilled in the center of the rod so the roll pin and the hydraulic arm will line up.  That thing is a pain to work on because it's so hard to get to.  I had to drill a new hole in my lift arm because the original was badly worn, so it can be done.  Good luck.
Don
  • Sawdust said thank you
