Power King Flywheel Housing?
12 replies to this topic
#1 MNGB ONLINE
MNGB
  • 1,252 Thanks
  • 957 posts
Posted November 16, 2014 - 09:50 PM
Hi all, I know over the years there were diferent models of the flywhel housing as far as the side top holes / slots, but were there differences in the mounting holes from one engine to another? Like were the B&S one different from the Kohler ones?
  • nbent said thank you
#2 David Brown OFFLINE
David Brown
  • 4,508 Thanks
  • 2,424 posts
Posted November 17, 2014 - 05:23 AM
To my knowledge (and that's not saying much) the hole pattern on that part is one of the only things that have actually been consistent over the years.  I've not heard of one not matching up in the time I've been exposed to these tractors.
#3 Username OFFLINE
Username
  • 2,069 Thanks
  • 1,425 posts
Posted November 17, 2014 - 07:54 AM
The small frame Jim Dandy with the Briggs 19 engine has a smaller bolt pattern.
  • David Brown said thank you
#4 MNGB ONLINE
MNGB
  • 1,252 Thanks
  • 957 posts
Posted November 17, 2014 - 10:40 AM
Ok what I'm wondering if  say a 1614 that is missing the Kohler could be repowered with a 16 hp B&S 32000 series. I have a rebuildable cast iron B&S and know of a 1614 with no engine but the rest is all there with the exception of one rear wheel or would it need to be a special series B&S to work?
#5 EconChuck OFFLINE
EconChuck
  • 251 Thanks
  • 289 posts
Posted November 17, 2014 - 11:28 AM
imo, if the Briggs engine that you are talking about is from the same year era as the Kohler then chances are that the engines should interchange "within reason". These engines and manufacturers had to maintain similar dimensions in order for the manufacturers of power equipment to offer what the customer wanted or to meet price points.
So if it has the 4 threaded bosses, has 7" pilot that the bellhousing centers on. The next concern would be crankshaft dia-1" or 1 1/8", also crank extension length which will affect clutch location and operation.
Good luck.
Chuck
#6 MNGB ONLINE
MNGB
  • 1,252 Thanks
  • 957 posts
Posted November 17, 2014 - 12:41 PM
Thanks much Chuck, I'll check it out some right now I'm not in a rush for a project tractor, I think the guy wants too much for it b ut he may need so extra cash in the future and come down. He thinks it worth $500.00 but I don;t.
  • Gtractor said thank you
#7 David Brown OFFLINE
David Brown
  • 4,508 Thanks
  • 2,424 posts
Posted November 17, 2014 - 01:00 PM
Right you are.  I was thinking strictly Power King models and wasn't sure if the Jim Dandy was smaller or not.  Hey, it's been a while for me.  I should probably stay off this board for fear of really messing someone up.
  • Username said thank you
#8 Username OFFLINE
Username
  • 2,069 Thanks
  • 1,425 posts
Posted November 17, 2014 - 01:16 PM
That was a tough one that I don't think many people know about.I found out the hard way.I think everyone has been wrong or corrected so please continue to share your knowledge.
#9 David Brown OFFLINE
David Brown
  • 4,508 Thanks
  • 2,424 posts
Posted November 17, 2014 - 01:24 PM
But the well is drying up man!
#10 Gtractor OFFLINE
Gtractor
    The Tractor Hoarder
  • 7,546 Thanks
  • 4,245 posts
Posted November 17, 2014 - 02:47 PM
With the dual tranny setup its not that far out of line price-wise.  How did he "lose" a wheel/tire combo?
#11 MNGB ONLINE
MNGB
  • 1,252 Thanks
  • 957 posts
Posted November 17, 2014 - 02:54 PM
Hi Gtractor, that's a good question, but I think what happened is someone borrowed it and never returned it, He told me that the engine (Kohler K321) needed overhaul he pulled took it to a small engine shop they OH'd it and it ran less than an hour and the rod seized and broke, he said they installed a bearing backward. I've never been into a Kohler but from the Briggs and other engines I've worked on I can't understand that, my thoughts is the rod may have been installed backward and didn't get any oil.
#12 Gtractor OFFLINE
Gtractor
    The Tractor Hoarder
  • 7,546 Thanks
  • 4,245 posts
Posted November 17, 2014 - 03:34 PM
..... but I think what happened is someone borrowed it and never returned it, .......
That would be "justifiable homicide"
#13 EconChuck OFFLINE
EconChuck
  • 251 Thanks
  • 289 posts
Posted November 17, 2014 - 04:42 PM
Hi,
I don't think $500 is too far out of line. The rod in Kohler K's appear to be a common failure point, either due to lack of lube, poor installation of new parts, A good 14 hp K321 is hard to beat in a Power King.
Chuck
