Sears Ff/18
17 replies to this topic
#16 Cat385B ONLINE
    HAZMAT CAT
  • 13,778 Thanks
  • 9,918 posts
Posted November 28, 2014 - 12:29 PM
One last thing, i have read that sears has their own size category 0, does this mean that any garden tractor implement i find on craigslist will or will not work? Reading this made me a bit confused.  Thanks again
The 'Suburban' tractors had the narrow 3 point, built earlier than your FF. Original Sears 3 point attachments are narrower than a standard Cat 0 three point. The spacing of the lower lift arms are 12" on Sears implements, whereas 'standard' is 20".
#17 KennyP ONLINE
  • 37,398 Thanks
  • 45,448 posts
Posted November 28, 2014 - 04:58 PM
Not a problem. I chatted with my uncle last nite and he will help me make the lift arms and adjusting link so i'm going to go ahead and order the weld on ball joint ends. Would it be ok if i used 2" bar instead of the 1.75"? Also where exactly does the stop assembly go? Do i really need it?
I have the tractor all torn down and going to attempt a paint job soon. I'll try and get a picture.
You won't have to worry on implements as the FF accepts 'REAL' Cat 0. The other you are talking about is an unreasonable facsimile!
The last bend out has a 34° angle. If you have any kind of drawing program, the other angle can be figured from there!
#18 tater195 ONLINE
tater195
  • 2,066 Thanks
  • 1,372 posts
Posted November 28, 2014 - 05:31 PM
just a wild quess from my conduit bending days, 34 degrees?
If you bend out 34 and bend in 34, you will be  parallel on both ends of the arm. Offset (space between the lift arms) will be determined by the distance between the bends. The balls in the lift arm will add some slop to the arms and bends are not needed in some cases. The most important thing to look at is the lift links should be as close to vertical as possible when hooked to a true cat0 implement.
  • KennyP and drbish have said thanks
