jd 110
14 replies to this topic
#1 ljones OFFLINE
ljones
  • 1 Thanks
  • 3 posts
Posted February 22, 2011 - 06:22 PM
I now have a jd 110, and it is having a few problems at the moment. The drive belt is sliping and the carb needs rebuilt, I will try to get some pictures up tomorrow.
#2 Bolens 1000 ONLINE
  • 14,987 Thanks
  • 18,140 posts
Posted February 22, 2011 - 06:36 PM
Welcome to the Forum!
Hopefully someone should be along to answer your question shortly
#3 caseguy OFFLINE
  • 1,628 Thanks
Posted February 22, 2011 - 07:08 PM
:wave: ljones Welcome to GTTalk! Glad to have you here. Pictures of your set-up would be helpful! I believe that your tractor has the vari-drive set-up on it?
#4 Tmo OFFLINE
Tmo
  • 360 Thanks
  • 486 posts
Posted February 22, 2011 - 07:29 PM
Lucas,
Roger H. and I gave you the right info on wfm. Be sure you have JD belts, and be sure they're the right belt. Also, do the adjustments outlined in the service manual I linked you to. You will find that the drive train on the belt drives are more forgiving than shaft drive tractors and less expensive to repair. But they do require adjustments from time to time. And using John Deere OEM belts is a must. They are manufactured to JD's strict specifications, not only the belt length and width, but also the angle of the V and thickness.
#5 grnspot110 ONLINE
grnspot110
  • 4,156 Thanks
  • 2,646 posts
Posted February 22, 2011 - 07:36 PM
Welcome!
Drive belt problem could be non-John Deere belts, The JD "V" belts have a different bevel than "standard" belts, so use only JD belts on these tractors. ~~ grnspot110
#6 daytime dave OFFLINE
  • 4,840 Thanks
  • 6,543 posts
Posted February 22, 2011 - 08:18 PM
ljones, welcome to the site. We love pictures.
#7 Tmo OFFLINE
Tmo
  • 360 Thanks
  • 486 posts
Posted February 22, 2011 - 08:46 PM
Lucas,
So do you still have your CCO and 122?
#8 nra1ifer OFFLINE
nra1ifer
  • 674 Thanks
  • 1,531 posts
Posted February 23, 2011 - 12:13 AM
Welcome!
#9 mjodrey OFFLINE
  • 2,356 Thanks
Posted February 23, 2011 - 05:14 AM
jd 110 ,:welcometogttalk:
Glad to have you with s.
#10 ljones OFFLINE
ljones
  • 1 Thanks
  • 3 posts
Posted February 24, 2011 - 05:49 PM
Here are the pics
  • Rozwell Ranch said thank you
#11 Bolens 1000 ONLINE
  • 14,987 Thanks
  • 18,140 posts
Posted February 25, 2011 - 07:21 AM
Nice Tractor
#12 MH81 OFFLINE
Posted February 25, 2011 - 02:27 PM
Sorry I missed this before. :welcome: to GTTALK. Nice tractor there.
#13 lyall ONLINE
lyall
  • 2,072 Thanks
  • 1,545 posts
Posted March 01, 2011 - 11:03 PM
Hi all
new here another great site for JD garden tractors
ljones
belt slippage sometimes it is not the belts it can be the pto that is slipping. I have to clean the pto from oil and/or grease and also remove the glazing on th pto liner. Mowing grass that is wet and tall the blades slow down almost to a stop. I know the belts are good and should not be slipping. Then I know it is time to look at the pto lining. To see if it has glazed over again. If the lining has a glaze to it I use a shoe rasp to light remove the glazing. Than go back to mowing. No slow down on the blades and cut the grass great again.
#14 ljones OFFLINE
ljones
  • 1 Thanks
  • 3 posts
Posted March 02, 2011 - 08:07 AM
lyall, it is the drive belt that is slipping, both of the belts on the tractor are the wrong size.
#15 tractorman1 OFFLINE
tractorman1
  • 1 posts
Posted March 02, 2011 - 01:12 PM
The variable speed lever might be out of adjustment or the belt could be stretched? There is also a spring loaded tensioner pulley located under the fender deck on the styled ones and under the frame on the older ones.
