Harbor Freight Tire Changer
26 replies to this topic
#1 Cat385B ONLINE
    HAZMAT CAT
  • 13,972 Thanks
  • 10,002 posts
Posted November 16, 2014 - 10:10 AM
Last weekend I got a flat on my Bolens G152.
So I was down to the Ariens ST824s.
I found slightly used turf tires on CL, mounted on Ingersoll rims.
Here is the old versus new comparison:
The old tires were tubed, and a crack between lugs pinched the tube. There are two cracks, each about 2-3 inches long. I might try to patch them, they are original to the tractor. (Made in Japan by Bridgestone)
Calling around to tire shops: I decided to have them switched out by a shop. I did the last ones on my Homelite T15, with screwdrivers and pry bars, and vowed never again. My FIL was there, and suggested a tire shop. About 6 times. Per hour. He once asked if I served in the Navy during the course of an old tire removal. Here are the responses from the tire shops, once I got my tubes, in no particular order:
We can fit you in, a week from Monday.
No thank you.
We don't do tractor rims. (My response was 'it's a 16x6 rim with a 225/75') They responded 'we don't do ag tires'. WTH?
One shop said they would not guarantee the tubes. I said I'm not looking for a warranty. He responded that he meant during installation, I should bring extras.
We only have two techs today. The ones I can see through the window vacuuming the rice burner?
That's where I said eff it, and went to Harbor Freight.
So we're mounted to a pallet on rugs in the heated garage, 93X is cranked, and one old tire is off. We'll do this one in real time, and post as I go. Only one smoke break per tire, no alcohol until the last one.
Unless it goes bad, then I'll start in ten minutes.
GO!
  • Bolens 1000, larrybl, hamman and 5 others have said thanks
#2 Cat385B ONLINE
    HAZMAT CAT
  • 13,972 Thanks
  • 10,002 posts
Posted November 16, 2014 - 10:14 AM
The dog needed out. Smoke break.
  • KennyP and superaben have said thanks
#3 KennyP ONLINE
  • 38,273 Thanks
  • 45,877 posts
Posted November 16, 2014 - 10:20 AM
You're not done yet? Pokey! I have one of those changers. Works pretty good, but not as good as having someone else do them! But it has paid for itself! I've even done the wheels off a Jeep!
  • Cat385B said thank you
#4 Gtractor ONLINE
Gtractor
    G-agressive tractor
  • 9,313 Thanks
  • 4,949 posts
Posted November 16, 2014 - 10:25 AM
Are we supposed to be taking bets on how long it is until the pallet boards self destruct and the new tire machine is laying sideways on the floor once the "UMPH" is put on there in an effort to break the bead?
:deadhorse:
  • Cat385B, LilysDad and superaben have said thanks
#5 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,982 Thanks
  • 4,409 posts
Posted November 16, 2014 - 10:32 AM
I was eyeballing one of those yesterday. Told my Wife that it would make a nice Christmas gift, along with the Shop Crane, Bench Drill Press, Table Saw, Compound Saw, Truck Dolly, and about half dozen other items. Thanks for the mounting option, as I wasn't sure how I would have mounted it.
  • Gtractor and Cat385B have said thanks
#6 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,836 Thanks
  • 2,331 posts
Posted November 16, 2014 - 10:41 AM
We have an older HF tire changer. The old shop manager cemented a steel pole into the ground and attached it to that. When we were doing the shop remodel, it had to go due to lack of use and simply being in the middle of the shop.
We since mounted it to a work bench made from 2X6s. It is still on there, but the center pole that's threaded isn't. Mostly due to the bead breaking. All our might, we have had little success with it. Flat heads and vice grips on the rim have been more successful with us.
We also have a tire shop that charges $5 to do the job. It's much cheaper to go that route.
#7 hamman OFFLINE
hamman
    Homelite Owner Extraordinaire
  • 6,436 Thanks
  • 2,860 posts
Posted November 16, 2014 - 10:53 AM
None of our tire places around here will do GT tires. They barely do boat trailer tires. Sad, lots of trailers and GTs around here. If we want tires done we have to take them 30 miles one way to get them done. I try to do them myself. Pry bars and lots of dawn dish soap. Might be a good place to open a tire and repair shop. Hope you get them fixed Scott.        Roger.
#8 Cat385B ONLINE
    HAZMAT CAT
  • 13,972 Thanks
  • 10,002 posts
Posted November 16, 2014 - 11:06 AM
First one done and mounted and chained.
  • Gtractor and hamman have said thanks
#9 Cat385B ONLINE
    HAZMAT CAT
  • 13,972 Thanks
  • 10,002 posts
Smoke break!
#10 glgrumpy ONLINE
  • 8,605 Thanks
  • 7,913 posts
Posted November 16, 2014 - 11:08 AM
Need a Firestone shop that does ALL tires. Mine is a few blocks away. Think it is about $7 to dismount, and another to Mount. They Will NOT mount someone elses New tires. Buy them there, mounting is free. They also prefer to use their tubes, not some you bring in. Can understand that, they are a business trying to make money you know.
I have that tire changer. I mounted mine on metal tube to go into my truck hitch. Sets a little high, but workable. Not as good on bead breaking, as have to hole or balance tire and wheel up there or set on blocks by truck. I have real good luck removing the tires with the tool. The "Holding" mechanism is just a bent bar, but is needed to keep wheel from turning, no matter how tight you make the clamp part. Where I have no luck is putting tire back on. The tool does not seem to want to stay in the rim and walks out as you turn it. maybe it is my technique?  Seems like it needs a sharper bend and little longer tab on end of tool??  I also found you can't do front  wheels and tires of GT's, as the holes for axle are too small to fit over the center post. Have had some I could knock out the bearings and would fit over, but that is rare. Bead breaker works on them still, a big help. Little ones are harder to hand change than big ones. I take them to shop, not breaking my B's doing those on floor.
#11 Cat385B ONLINE
    HAZMAT CAT
  • 13,972 Thanks
  • 10,002 posts
Posted November 16, 2014 - 11:10 AM
I read the reviews and thought the attached bead breaker was crap. So I got one:
  • Gtractor, hamman and LilysDad have said thanks
#12 wilberj ONLINE
wilberj
  • 5,003 Thanks
  • 5,595 posts
Posted November 16, 2014 - 11:14 AM
Hey you maybe done befor lunch!
#13 KennyP ONLINE
  • 38,273 Thanks
  • 45,877 posts
Posted November 16, 2014 - 11:21 AM
I have used the bead breaker with success. My machine is mounted to concrete. I built a holder for the front wheels.
  • Gtractor, hamman and Bmerf have said thanks
#14 KC9KAS ONLINE
KC9KAS
  • 5,383 Thanks
  • 4,690 posts
Posted November 16, 2014 - 11:48 AM
I bought this one...
Works very well, but need to do some fabrication for front (3/4") diameter axle wheels.
  • hamman said thank you
#15 Cat385B ONLINE
    HAZMAT CAT
  • 13,972 Thanks
  • 10,002 posts
Posted November 16, 2014 - 11:53 AM
Ready to go:
MNGB, send me a PM about these darn Ingersoll rims I keep tripping over, if you want them.
  • Bmerf said thank you
