Wisconsin Twins Acquired, Need Help
28 replies to this topic
#16 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted November 16, 2014 - 12:40 PM
Pulled the plugs, they are above the valves.... So not going to get much info there.
This post threw it to page two, pics on page one.
Edited by wvbuzzmaster, November 16, 2014 - 12:41 PM.
#17 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted November 16, 2014 - 02:31 PM
Casey, you'll need to pull off the head to know more.
Your engine would have had a magneto, and it should have a fuel pump.   I like that it has a governor.
Ben W.
  • wvbuzzmaster said thank you
#18 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted November 16, 2014 - 02:35 PM
Ben,
I know there should be a fuel pump, but would electric fuel pump suffice in this scenario.
Also, how much is a magneto and and carburetor going to run me? I know I have to pull the head to know which, but looking for a little direction.
  • superaben said thank you
#19 MFDAC OFFLINE
MFDAC
  • 3,152 Thanks
  • 1,568 posts
Posted November 16, 2014 - 03:02 PM
Good info here. My TF, like Ben said is 3.25" bore and the stroke is too, according to the tag. Looks much like the engines you pictured here, WV.
DAC
#20 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted November 16, 2014 - 04:29 PM
Ben,
An electric fuel pump would work.
Technically, there are different carburetors for a fuel pump versus non fuel pump engine.  I think I have one cast iron Zenith for you, and a couple aluminum Zeniths.   Aluminum Zeniths are cheaper.  I think I sell them for $125.
The magnetos are a different story.  If it is a dual spark mag, you are looking at $200.  If it is a TJD with a timed mag, you are looking at $250.
All those parts are cleaned, rebuilt, ready to roll.  I sell a lot of them.
Ben W.
#21 Gtractor ONLINE
Gtractor
    G-agressive tractor
  • 9,112 Thanks
  • 4,883 posts
Posted November 16, 2014 - 07:09 PM
Buzz,
If your application will allow the fuel tank to be mounted higher than the carb,  just gravity the fuel in.
#22 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted November 16, 2014 - 07:24 PM
Buzz,
Yes, could do that, but not sure what I will power with it given it may be 350 to make it run....
#23 olcowhand ONLINE
  • 40,352 Thanks
  • 31,171 posts
Posted November 16, 2014 - 07:33 PM
I use an electric fuel pump with my TJD, but the floats in the carbs can easily be overpowered by 3psi pumps.  So I used a pressure regulator with my elec pump, set to 1.5psi.  Haven't had any problems since.  You could make your own regulator by putting a T in the line just ahead of the carb, with a restrictor in the return line back to the tank, or T back into the fuel line ahead of the fuel pump.
  • wvbuzzmaster and superaben have said thanks
#24 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted November 16, 2014 - 08:12 PM
Its not cheap if I provide the magneto and carb without getting any cores back.  If you find a magneto and carburetor, rebuilds are much, much, much cheaper!!
Ben W.
#25 IamSherwood OFFLINE
  • 8,390 Thanks
Posted November 16, 2014 - 08:26 PM
Alright, alright, already!
The sun has gone down. Can we get this thread back on track
to it's original intent?
The Twins! From Wisconsin!
So, Casey, what'd they do today? Make Cheese?
#26 Sparky OFFLINE
Sparky
  • 1,296 Thanks
  • 1,892 posts
Posted November 16, 2014 - 09:02 PM
Two Stellas ? How big would that kitchen have to be ?
  • DH1 said thank you
#27 Cat385B ONLINE
    HAZMAT CAT
  • 13,780 Thanks
  • 9,918 posts
Posted November 16, 2014 - 09:05 PM
I Googled Wisconsin twins, and I got these:
They are twins who ran the Iditarod.
I don't blame ya for wanting to get the engines running, Casey. Having those two and a team of Huskies pulling your GT around would be awfully distracting.
  • IamSherwood said thank you
#28 IamSherwood OFFLINE
  • 8,390 Thanks
Posted November 16, 2014 - 09:19 PM
So, do you think what happened here, is that they conquered the Iditarod, and then
got online, looking for their next
challenge, and zeroed in on Casey?
#29 DougT ONLINE
DougT
    Dog Approved
  • 6,852 Thanks
  • 4,953 posts
Posted November 16, 2014 - 09:58 PM
That has to be it, Will. How else would Casey end up with a pair of twins like that??
