Gas Vapor
8 replies to this topic
#1 lyall OFFLINE
lyall
  • 2,072 Thanks
  • 1,545 posts
Posted November 15, 2014 - 11:16 PM
has anybody tried using gas vapors to run a motor
been watching "the vaporkid" on youtube - looks like he has something to look into
here is the link for "the vaporkid" on youtube
http://www.youtube.c...Vaporkid/videos
I have been thinking about building a unit for one of my Deere 214 that I have.
it is one I brought to rebuild - took it all taken apart, checked over and part back together.
I was planning on selling it next spring, but it would be a good test unit to try to run it on gas vapors
what do you all think about the idea of running on gas vapors?
would like to hear your thoughts about it
thanks
  • Cvans said thank you
#2 Cvans OFFLINE
  • 6,648 Thanks
  • 6,129 posts
Posted November 15, 2014 - 11:52 PM
There are quite a few videos on U-tube about guys driving there vehicles on vapor so your tractor should be doable. Keep is posted on how your project goes for you please.
#3 MH81 OFFLINE
Posted November 16, 2014 - 12:38 AM
Interesting concept.
I would say a word about caution and safety. So often, mock ups and experimentals lack safety features... I would suggest to use as many safety protocols as possible on this.
  • lyall and tractorgarden have said thanks
#4 DennyIN ONLINE
DennyIN
  • 343 Thanks
  • 207 posts
Posted November 16, 2014 - 07:47 AM
One of the first I heard of was the Charles Pogue Carburetor, then Tom Ogle, but it was for a car. Grab your coffee cup if you start to research it though, it is never ending.
  • lyall said thank you
#5 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted November 16, 2014 - 10:09 AM
Haven't researched it so I have to ask: what is the gain? Because you have x btu's per gallon. Propane has fewer btu's/gallon and therefore gets worse efficiency than gasoline.
Mike
#6 Cvans OFFLINE
  • 6,648 Thanks
  • 6,129 posts
Posted November 16, 2014 - 10:12 AM
Vapor is far more combustible than liquid. Burns faster and cleaner than liquid.
Edited by Cvans, November 16, 2014 - 10:14 AM.
#7 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted November 16, 2014 - 10:38 AM
worked a few of these fires back when I was with the fire dept..
#8 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted November 16, 2014 - 03:12 PM
  So if it burns faster does this mean you'll have pre-ignition or timing  problems?
                                              Mike
#9 Cvans OFFLINE
  • 6,648 Thanks
  • 6,129 posts
Posted November 16, 2014 - 11:05 PM
There is a few things that play into this but basically the answer is "no". Octane shouldn't change. Part of the fuel is vaporized in a normal engine before combustion when it comes in contact with heated surfaces inside the engine.
Edited by Cvans, November 16, 2014 - 11:06 PM.
