Made An Axle On My Table Saw
24 replies to this topic
#16 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted November 14, 2014 - 09:54 PM
Great idea! :thumbs:
#17 diesel nut ONLINE
diesel nut
  • 700 Thanks
  • 426 posts
Posted November 14, 2014 - 10:40 PM
This is a real good idea.  I'll have to remember for the next time I need to make stuff with key ways.                Stewart
#18 Little Irish Men OFFLINE
Little Irish Men
  • 825 Thanks
  • 470 posts
Posted November 15, 2014 - 02:01 PM
From a wood shop to a machine shop . Very nice
#19 chieffan OFFLINE
  • 10,135 Thanks
  • 6,632 posts
Posted December 29, 2014 - 09:00 PM
Woodworking tools were not meant for metal working  BUT - as long as you take it easy and let the machine do the work and don't force it, they will do a lot more than intended. Nice job there for sure.  Machine shop would have charged you a couple hundred to do that.
#20 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,295 Thanks
  • 9,777 posts
Posted December 30, 2014 - 08:41 AM
Give yourself a medal for bravery! I see a lot of places where I would have encountered disaster. Radial saws are not my friiends.
How did you lock the drill press at depth for milling?
#21 New.Canadian.DB.Owner OFFLINE
  • 2,331 Thanks
  • 1,498 posts
Posted December 30, 2014 - 07:58 PM
The drill press has a height adjustment lock that does both upper & lower limiting.
  • LilysDad said thank you
#22 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted December 30, 2014 - 08:40 PM
you can do a lot of things with a drill press. A friend of mine uses his to make hubs for garden carts. I have one fairly big press with a 6" quill stroke. It also will lay down like a lathe.
I have see attachments in an old Sears catalog for doing metal work with there radial arm saw. Using a cutoff wheel instead of a blade, you should be able to do several lite duty projects.
  • New.Canadian.DB.Owner and Sawdust have said thanks
#23 Sawdust ONLINE
Sawdust
  • 5,656 Thanks
  • 3,370 posts
Posted December 30, 2014 - 09:28 PM
This was a good project to follow. Very clever use of what you have. Being a carpenter & recently getting into rebuilding tractors this definitely got my interest. I've done a few things that weren't meant to do with woodworking tools but like mentioned extreme caution & letting the tool do the work things c work out well. Most of the cutoff wheels I use have a very high rpm rating much more than the table saw or radial arm saw. Good job & saved yourself some pocket money.
#24 New.Canadian.DB.Owner OFFLINE
  • 2,331 Thanks
  • 1,498 posts
Posted January 21, 2015 - 06:32 PM
Came across this video today & thought the first 13 minutes seemed to go well with the thread.
Edited by New.Canadian.DB.Owner, January 21, 2015 - 06:33 PM.
  • gopher said thank you
#25 MH81 OFFLINE
Posted January 21, 2015 - 08:47 PM
Missed this, great use of the old noggin and the equipment you have to work with.
