Made An Axle On My Table Saw
24 replies to this topic
  • 2,331 Thanks
  • 1,499 posts
Posted November 14, 2014 - 06:27 PM
In fairness, I also needed my radial arm saw, drill press, and angle grinder.
Some of you may remember that I spent $240 to have an axle made for the Supremacy 45 I accidentally started to restore when I found the crankcase full of water.  Lauber1 suggested I should get some access to machine tools, so when I decided to replace the axle on my Waterloo 15 (bad groove at the oil seal) I started looking around.  I figured I would need a milling machine, but they look like my drill press.  That got me thinking that my radial arm saw looks like a surface grinder.  I have used the table saw to make dadoes in wood projects.  Metal is just really hard wood, right?  Both are carbon based.
So, anyway, I called around & found 1" cold rolled 1018 round rod for $4 a foot.  They have a $15 minimum, and I needed 26.5 inches.  Quick math & I bought 9 feet (4 sections, no waste, gotta have a spare anyway).  It came as 2 pieces, each 4 1/2 feet long, so I used the radial arm saw to cut one of them into two pieces 26.5 inches long.
I made a jig out of some wood, not the best choice, but it is what I had.
I secured one piece in the jig and drilled the hole for the drive gear setscrew.  I then flipped the drill guide over & locked the axle into the jig with a 1/4" bolt through a nut I had welded onto it.
From there it was off to the radial arm saw with a 3/4" fine grinding wheel.  That made the flat spots on the ends of the axles where the locking bolts ride.
Then it was off to the table saw to cut the key way groove for the clicker hub key.  I used two 1/8" cut off wheels to make the 1/4" key way. They left a small ridge down the centre, which I cleaned up with an end mill in my drill press.  My angle grinder cleaned up the run-out portion of the keyway.
That's where the easy part ended.  The keyway for the drive gear is directly below the bolt I had installed to lock the axle in place & maintain the alignment of all of the grooves & flats.  To spin the axle 180* and keep the alignments spot on, I drilled a hole through the drilling guide & out the bottom of the jig.  When I rotated the axle, I slipped a 1/4" pin into the hole from the bottom and into the drive gear setscrew hole.  While I was turning the axle I marked the location for the drive gear keyway.  Then it was back to the drill press and the end mill to make the keyway.  The original axle used a woodruff key, but I went with 1/4" square stock rounded on the ends.  I dimpled the lip of the set screw to keep it from loosening off.
While I had it apart, I figured I might as well make some new clicker springs for the ratchet hubs.
It is all back together and runs like new.  Time will tell if the oil leak is fixed.  Now I can get back to the oil leak on my Allis HB112.
  • olcowhand, Bill56, MH81 and 17 others have said thanks
  • 6,461 Thanks
  • 3,473 posts
Posted November 14, 2014 - 06:47 PM
Clever approach, using what's on hand keeps money in your pocket.
  • Bill56 and New.Canadian.DB.Owner have said thanks
#3 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted November 14, 2014 - 07:07 PM
Difference in a mechanic and a parts changer!
  • New.Canadian.DB.Owner and Sawdust have said thanks
#4 KennyP ONLINE
  • 39,184 Thanks
  • 46,334 posts
Posted November 14, 2014 - 07:09 PM
Nice approach to making the axle!
#5 tater195 ONLINE
  • 2,216 Thanks
  • 1,419 posts
Posted November 14, 2014 - 07:14 PM
I would have tried an angle grinder.
Nice job on the keyway!!!
#6 massey driver OFFLINE
massey driver
  • 1,431 Thanks
  • 1,580 posts
Posted November 14, 2014 - 07:21 PM
Nice job with using tools what you had on hand to get the job done.It's amazing what we can do with the tools that we have. Goodwork.
  • 5,419 Thanks
  • 4,704 posts
Posted November 14, 2014 - 07:28 PM
Very clever! Great job on the axle.
#8 Alc OFFLINE
  • 7,034 Thanks
  • 7,500 posts
Posted November 14, 2014 - 07:35 PM
Great Job !! What away to use the tools you hand on hand  !
#9 IamSherwood OFFLINE
  • 8,391 Thanks
Posted November 14, 2014 - 07:59 PM
That's using the old noodle Mark. :thumbs:
#10 lyall ONLINE
  • 2,123 Thanks
  • 1,560 posts
Posted November 14, 2014 - 08:01 PM
good use of the brain power to think it through
#11 gopher OFFLINE
  • 765 Thanks
  • 759 posts
Posted November 14, 2014 - 08:02 PM
Just a side note. BE VERY careful when putting cut off wheels on saws that might have higher rpm's then blade rated. Could be really  bad outcome.
  • New.Canadian.DB.Owner, LilysDad and Genem have said thanks
#12 olcowhand ONLINE
  • 41,912 Thanks
  • 31,643 posts
Posted November 14, 2014 - 08:21 PM
Very nice work with what ya got.  I figure it'll seal fine, as there's no reason it shouldn't.  :thumbs:
  • New.Canadian.DB.Owner and Gabriel have said thanks
#13 trowel OFFLINE
  • 4,823 Thanks
  • 4,533 posts
Posted November 14, 2014 - 08:33 PM
Wow mark, that is clever as all heck, I love the saw idea !
#14 Gabriel OFFLINE
  • 1,443 Thanks
  • 1,859 posts
Posted November 14, 2014 - 09:21 PM
Nice work!
#15 Lauber1 OFFLINE
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted November 14, 2014 - 09:26 PM
I knew you could make one your self, it just takes some out of the box thinking sometimes.
