Tractor Storage Outside?
tractor storage
13 replies to this topic
  • 10,344 Thanks
Posted November 13, 2014 - 10:15 AM
Wondering how many of you guys store some of your tractors, garden tractors, attachments and other equipment outside? If you do, do you store it in any special way? We definitely need to do something with a storage shed or building at some point but it might be another year or so till that happens.
We have put stuff on skids and covered with a tarp but it still doesn't seem to help with the moisture and actually seems to make it worse. So with that being said, for those of you that store stuff outside I want to know how you help preserve it.
  • tinbender7 and Sawdust have said thanks
  • 6,432 Thanks
  • 3,470 posts
Posted November 13, 2014 - 10:32 AM
Spray with CRC put plastic down on the ground to prevent flashing of moisture.Cover with moving blanket and then tarp wrap well that's me George.
  • Alc, IamSherwood, tinbender7 and 2 others have said thanks
#3 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted November 13, 2014 - 10:33 AM
You might consider putting a pallet or something like that on top and leaving the ends of the tarp open to allow air to pass through.  I've done this before with my 4 foot brush hog.  I have two old Wheelhorses outside and I have a piece of steel roofing laying over top of both of them and then a tarp on top of that.  Works pretty well.
  • Alc, IamSherwood, boyscout862 and 1 other said thanks
#4 boyscout862 ONLINE
  • 13,240 Thanks
  • 9,294 posts
Posted November 13, 2014 - 10:41 AM
The ventilation is critical. Otherwise the cover will make it like a sauna inside and it will corrode faster. I use big plastic bags but leave atleast one side not touching the ground. Good Luck, Rick
  • Gtractor, Alc and tinbender7 have said thanks
#5 baerpath OFFLINE
  • 314 Thanks
  • 514 posts
Posted November 13, 2014 - 12:12 PM
Watch craigslist for Calf Huts. Most are large enough to put a tractor in and one ends partially open They work great
  • Alc, propane1 and jerseyhawg / glenn have said thanks
#6 Bolens 1000 ONLINE
  • 15,145 Thanks
  • 18,191 posts
Posted November 13, 2014 - 12:23 PM
I store a few parts machines and implememnts on pallets with garden tractor tarps that cover everything. The pallets are left open on the bottom for ventilation.
  • Gtractor and Alc have said thanks
#7 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted November 13, 2014 - 02:53 PM
Misting them down with some sort of rust inhibitor is a help, although it does make a mess. Fluid film, rust check etc.
#8 propane1 ONLINE
  • 8,972 Thanks
  • 4,222 posts
Posted November 13, 2014 - 04:59 PM
You need air flow, because condensation will rust them.  Plus rodents like places that have no wind.  They will nest there for the winter.  Mice filled the flywheel with insulation from the side panels on my 165 ford one time, so tight the engine would not turn over.  Noel
#9 Titus OFFLINE
    Bush Hog Hoarder
  • 1,843 Thanks
  • 2,334 posts
Posted November 13, 2014 - 05:04 PM
I tarp mine. I had a shed, which mother nature decided it was within her best interests to take down with heavy snow.
I need a workshop or storage shed to keep them in.
We're supposed to get snow tonight and tomorrow for the 1st time this year, and I am far from ready for it.
  • Alc and propane1 have said thanks
#10 Alc OFFLINE
  • 7,027 Thanks
  • 7,499 posts
Posted November 13, 2014 - 05:31 PM
My implements are mostly outside , I spray a WD40/motor oil mix on them . For winter I park the PK outside with the 6' snow blade next to the garage under a tarp . It doesn't touch the ground just kind of wrapped around to keep the rain and snow off . I don't do anything extra for that though .
#11 jabelman OFFLINE
  • 2,237 Thanks
  • 1,600 posts
Posted November 13, 2014 - 06:30 PM
Dont forget the mice. They like to chew on important wires etc...
  • boyscout862, propane1 and jerseyhawg / glenn have said thanks
#12 KBear OFFLINE
    Garden Tractor Nerd
  • 90 Thanks
  • 126 posts
Posted November 13, 2014 - 11:21 PM
I was just reading a thread on another LGT forum about Harber Freight's Portable Garage. It's a thought for a temporary shelter?
Edited by KBear, November 13, 2014 - 11:22 PM.
#13 Cvans ONLINE
  • 6,833 Thanks
  • 6,195 posts
Posted November 14, 2014 - 12:19 AM
If you have to use a tarp, leave the bottom off of the ground a little ways so you have some air movement. Sun and moisture are your two biggest enemies.
#14 Reverend Blair OFFLINE
Reverend Blair
  • 501 Thanks
  • 952 posts
Posted November 15, 2014 - 04:02 PM
Yeah, tarps with airflow.  I use cindercrete blocks to hold the corners down.  I keep anything with an engine inside though. My garage and my shed are both unheated, so mice aren't much of a problem.
I do have to leave my dump truck outside because there's no room for it anywhere else.  I don't tarp it.  I change the oil, check the antifreeze, and pull the battery. Then I walk away from it until the ground dries up in the spring.
  • propane1 said thank you
Also tagged with one or more of these keywords: tractor, storage
