Fuel Additive
18 replies to this topic
#1 LilysDad OFFLINE
LilysDad
    Millennium Falcon
  • 13,329 Thanks
  • 9,795 posts
Posted November 12, 2014 - 11:30 AM
I went and got an oil change at the Chrysler dealer today. This was for a 2011 Town $ Country. The service manager offered me a $30 fuel additive to remove fuel tank condensate "caused by seasonal temperature fluctuations".
Well, I said, I thought that gasohol would absorb water, that's why no one buys HEET anymore. He stated again that this moisture settles to the bottom of the tank. Really??? Is it still on the bottom after I've been driving for 15 minutes?
What do you all think?
  • rustyoldjunk said thank you
#2 Jack OFFLINE
Jack
  • 1,290 Thanks
  • 857 posts
Posted November 12, 2014 - 11:47 AM
Sounds like a bunch of Hooey to me...  :say_what:
  • LilysDad said thank you
#3 Trav1s OFFLINE
Trav1s
  • 3,313 Thanks
  • 4,367 posts
Posted November 12, 2014 - 12:24 PM
There is a problem with condensation at the bottom of underground fuel storage tanks.  Service stations are very careful to not levels go too low or the pumps will pick up the water.  A quick google search shows that water weighs just over 8.3 lbs/gallon and gasoline weighs approx 6.25lbs/gal.  Which one is heavier?  Which one is at the bottom of the tank?  2 lbs is a significant difference in weight.
Edited by Trav1s, November 12, 2014 - 12:24 PM.
  • rustyoldjunk and LilysDad have said thanks
#4 rustyoldjunk OFFLINE
rustyoldjunk
    Has anybody seen my coffee ?
  • 2,625 Thanks
  • 1,311 posts
Posted November 12, 2014 - 12:58 PM
I believe that ethanol draws moisture. I use Seafoam and marine formula Stabil.
  • Cat385B, LilysDad and A.C.T. have said thanks
#5 HANKG OFFLINE
HANKG
  • 6,323 Thanks
  • 3,427 posts
Posted November 12, 2014 - 01:55 PM
Stabil ethanol and fuel stabilizer treatment 32 oz bottle $ 24.00 treats 320 gal of  gas.   So yea I think he was trying to poke in your business unless he was giving you the remaining 28 ounces 1oz per 10 gal.
Edited by HANKG, November 12, 2014 - 02:04 PM.
#6 LilysDad OFFLINE
LilysDad
    Millennium Falcon
  • 13,329 Thanks
  • 9,795 posts
Posted November 12, 2014 - 02:08 PM
Water is certainly heavier than straight gas and will settle to the bottom if it's not agitated.
That's a much better deal!
  • Cvans said thank you
#7 HDWildBill OFFLINE
  • 8,975 Thanks
Posted November 12, 2014 - 02:52 PM
+1  I can't see any gas treatment costing that much.
#8 Bill 76 OFFLINE
Bill 76
  • 1,947 Thanks
  • 1,196 posts
Posted November 12, 2014 - 03:22 PM
Snake oil
#9 Gtractor OFFLINE
Gtractor
    G-agressive tractor
  • 9,347 Thanks
  • 4,960 posts
Posted November 12, 2014 - 03:24 PM
He works on commission.  You don't need it.
#10 tater195 ONLINE
tater195
  • 2,200 Thanks
  • 1,413 posts
Posted November 12, 2014 - 03:36 PM
Heet is 95% methanol. Gas is 10% methanol..... snake oil
#11 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted November 12, 2014 - 03:45 PM
cant get a mechanic in a can.  im sure every car does have slight amounts of water in the gas but it dosent effect it
#12 Cvans ONLINE
  • 6,668 Thanks
  • 6,134 posts
Posted November 12, 2014 - 03:52 PM
Old 850 Ford tractor. The sediment bowl was half full of water and badly discolored. Tractor is not running good. Drained the bowl and added 1/2 a tank of 10% ethanol. Couple hours later the old tractor is running like a champ and the float bowl looks like new. Not a bit of discoloration left. That stuff is a pretty strong solvent if you ask me.
#13 HANKG OFFLINE
HANKG
  • 6,323 Thanks
  • 3,427 posts
Posted November 12, 2014 - 04:09 PM
It was 70 degree's at the NJ shore today it is to be 35 degree's tomorrow morning that is the kind of temperature change that can cause condensation in fuel tanks unless there full. After the temp stabilizes no worries.
#14 olcowhand ONLINE
  • 41,262 Thanks
  • 31,447 posts
Posted November 12, 2014 - 04:39 PM
Nope, don't buy it.  Now I do like to use a can of Seafoam maybe once a year for the cleaning benefits, but it's less than $9.  Never heard of any additive costing $30!
#15 Username OFFLINE
Username
  • 2,072 Thanks
  • 1,425 posts
Posted November 12, 2014 - 04:46 PM
Interesting read:
http://www.fuel-test...thanol_gas.html
  • Cvans, A.C.T. and 1oldbuzz have said thanks
