Bolens Cut Out And Lost All Power
23 replies to this topic
#16 Canawler ONLINE
Canawler
  • 1,948 Thanks
  • 1,801 posts
Posted November 12, 2014 - 09:21 AM
Jim, I think he is talking about the starter solenoid. It might have one of those where the power has to go through the solenoid out a terminal at the bottom to the switch for "power in".
Ben W.
Right, regarding the electrical issues. I was addressing the comments about having no fuel and needing to rebuild the carb. If it has a fuel shut-off solenoid and electrical issues, there might not be anything wrong with the carb, just no fuel flow due to the shut-off not having power.
  • superaben said thank you
#17 Ron Dziedzic OFFLINE
Ron Dziedzic
  • 83 Thanks
  • 114 posts
Posted November 12, 2014 - 09:34 AM
So with what you are saying then it would be just the solenoid?
#18 Ron Dziedzic OFFLINE
Ron Dziedzic
  • 83 Thanks
  • 114 posts
Posted November 12, 2014 - 09:37 AM
Also with that being said I know the electric lift is operated through the solenoid and I'm pretty sure that is what burned it out now once this is fixed should I possibly run the lift straight to the battery with a fuse so that way I'm not burning up my solenoid again in the future then it would just blow the fuse instead
Edited by Ron Dziedzic, November 12, 2014 - 09:38 AM.
#19 Jehtro OFFLINE
Jehtro
  • 109 Thanks
  • 276 posts
Posted November 13, 2014 - 09:10 PM
Check battery to frame ground connection as well.
JD 318 just did that, ground was bad , looked okay at the battery post,
#20 Ron Dziedzic OFFLINE
Ron Dziedzic
  • 83 Thanks
  • 114 posts
Posted November 15, 2014 - 10:14 AM
Ok I have a new ignition switch and a new solenoid I did find a bad fuse and I did replace that also but still I have nothing. I did find the wiring diagram online so now I am going to start tracking my power till I don't have any but wow dose this one have alot of wires lol
#21 Ron Dziedzic OFFLINE
Ron Dziedzic
  • 83 Thanks
  • 114 posts
Posted November 15, 2014 - 10:15 AM
Any more tips are always welcome
#22 Ron Dziedzic OFFLINE
Ron Dziedzic
  • 83 Thanks
  • 114 posts
Posted November 16, 2014 - 12:45 PM
It's all fixed
  • Gabriel said thank you
#23 Bolens 1000 ONLINE
  • 14,903 Thanks
  • 18,103 posts
Posted November 16, 2014 - 04:04 PM
What did you end up doing to fix it?
#24 Ron Dziedzic OFFLINE
Ron Dziedzic
  • 83 Thanks
  • 114 posts
Posted November 17, 2014 - 10:54 AM
I ended up finding a loose ground a burnt fuse and a bad solenoid and it seems that all three kept it from doing eny thing and you couldn't see that the fuse was bad but it was when I tested it
Edited by Ron Dziedzic, November 17, 2014 - 10:55 AM.
