Goes To Sleep
11 replies to this topic
#1 efedak OFFLINE
efedak
  • 1 Thanks
  • 11 posts
Posted November 10, 2014 - 08:16 PM
a friend of mine has a decent early 80's case, I don't know the model, and told me today that it is up for sale but didn't say how much. I ask why and he said that after about an hours work it decides to take a nap, after it cools off it'll run for another hour or so. does any one have any thoughts as to what could be the problem here? I've read that they are real picky about the oil you're supposed to use.
#2 johndeereelfman OFFLINE
johndeereelfman
    Elfin Majic
  • 5,509 Thanks
  • 2,542 posts
Posted November 10, 2014 - 08:25 PM
Could be a sticking push rod. Heats up and swells, then shrinks during cool down.
#3 petrj6 ONLINE
petrj6
  • 3,878 Thanks
  • 2,260 posts
Posted November 10, 2014 - 08:26 PM
   Take a nap???  A little more details would help, Is the engine quitting?  if so when it quits does it stop suddenly( locked up ) or does it just die slowly ( coil getting hot and quitting )  Or does it stop driving?
#4 DougT ONLINE
DougT
    Dog Approved
  • 5,908 Thanks
  • 4,379 posts
Posted November 10, 2014 - 08:31 PM
I have to agree with Pete. Lots of variables in that equation.
#5 KennyP ONLINE
  • 29,410 Thanks
  • 40,401 posts
Posted November 10, 2014 - 08:32 PM
Sounds a lot like me! After about an hour, I'm ready for a nap!
  • Bill56, rustyoldjunk, dropped82 and 2 others have said thanks
#6 superaben OFFLINE
superaben
  • 7,665 Thanks
  • 5,677 posts
Posted November 10, 2014 - 08:33 PM
An hour is a little long for vapor lock.  I'm leaning towards a coil if it is engine related.
What model Case are you working on?  What engine is in it?
Ben W.
  • rustyoldjunk said thank you
#7 dropped82 ONLINE
dropped82
    Nut Case
  • 1,538 Thanks
  • 1,294 posts
Posted November 10, 2014 - 08:34 PM
Sounds like you need a new coil Kenny.
I'm thinking coil or condenser also. There's a lot of heat under the hoods of these things. They like to melt the decals and paint off over time.
  • rustyoldjunk and KennyP have said thanks
#8 JDBrian OFFLINE
  • 9,591 Thanks
Posted November 11, 2014 - 07:33 AM
I would carry a spark tester with me and when it quit I'd check for spark. No spark and you have narrowed the problem down considerably. Most likely it's the coil if it does it that consistently. If it was converted to SS ignition that may be another source of trouble.
#9 TAHOE ONLINE
TAHOE
  • 6,581 Thanks
  • 5,011 posts
Posted November 11, 2014 - 08:30 AM
Ben W.
:ditto:
#10 efedak OFFLINE
efedak
  • 1 Thanks
  • 11 posts
Posted November 11, 2014 - 07:39 PM
my deepest apologizes, the engine runs great, and stays running, the tractor slows down and won't pull it's own weight
#11 Cat385B ONLINE
    Therapy CAT
  • 12,087 Thanks
  • 9,087 posts
Posted November 11, 2014 - 08:14 PM
Sounds like wrong oil, blocked cooler issue, or contamination in oil issue.
  • dropped82 said thank you
#12 1031d OFFLINE
1031d
  • 32 Thanks
  • 90 posts
Posted November 13, 2014 - 07:47 PM
Could be the wrong oil also. Should use Rotella 15W-40.
