Case/ingersoll 4 Series Rear Rim Bolt Spacing
11 replies to this topic
#1 Cat385B ONLINE
    HAZMAT CAT
  • 13,780 Thanks
  • 9,919 posts
Posted November 10, 2014 - 08:10 PM
What is the bolt spacing/pattern on the later Case and Ingersoll 4 series tractors? I need new tires for my SCUT, and these are available reasonable:
I am wondering if I'm going to swapping tires, or get lucky and bolt those rims right onto my diesel disappointer.
#2 Cat385B ONLINE
    HAZMAT CAT
  • 13,780 Thanks
  • 9,919 posts
Posted November 10, 2014 - 08:27 PM
My hub is 3.5" diameter, roughly 4&5/8" straight across bolt to bolt.
PS - How are you supposed to measure bolt patterns?
#3 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted November 10, 2014 - 08:34 PM
With a measuring tape, Scott.  :poke: :D
Ben W.
  • KennyP, Cat385B, Nato77 and 1 other said thanks
#4 Bill 76 ONLINE
Bill 76
  • 1,892 Thanks
  • 1,178 posts
Posted November 10, 2014 - 08:35 PM
6 lug wheels are measured from center of LUG hole to center of LUG hole straight across.                Bill
Edited by Bill 76, November 10, 2014 - 08:53 PM.
  • Cat385B said thank you
#5 Cat385B ONLINE
    HAZMAT CAT
  • 13,780 Thanks
  • 9,919 posts
Posted November 10, 2014 - 09:22 PM
Then I'm sticking with 4&5/8". Thanks, Bill.
Ben, may a diseased yak visit your bathtub while you're in it. And I'm still uncomfortable with you being the official 'Cat Scratcher'. Not even sure what that would entail.
#6 glgrumpy OFFLINE
  • 8,559 Thanks
  • 7,878 posts
Posted November 10, 2014 - 09:36 PM
These wheels will fit many 6 bolt tractors I would think. I had some once on my Power King, but the off set was a lot less and couldn't bolt on the fenders then, which had mounting angle irons down to gear case inside wheel. That off set is only odd thing I know about them. My .02 worth!  Newer bigger tractors may have Metric dimensions would think and would also think the studs would be bigger diameter?
#7 Cat385B ONLINE
    HAZMAT CAT
  • 13,780 Thanks
  • 9,919 posts
Posted November 10, 2014 - 09:44 PM
My tractor is not newer, barely bigger, and it is indeed metric. I can run my rims wide or narrow, and my offset on the factory rims are nearly flush with the bead of the rim. (narrow) Set up narrow, I have a 39" width. At wide, I am at 46".
Wide:
#8 EconChuck OFFLINE
EconChuck
  • 252 Thanks
  • 289 posts
Hi,
 Typically, a 6 bolt wheel for the Case 4 seriesl and the Economy Power King is 6" bolt circle and the hub dia/center hole is 4 5/8" dia. As GL suggested the back spacing is different between the Case and Economy tractors and people may not like swapping from one brand to the other.
Chuck
Edited by EconChuck, November 10, 2014 - 09:48 PM.
#9 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted November 10, 2014 - 10:18 PM
I don't know what a diseased yak is like, but I tell you what, if it comes in my bathroom while I'm in the tub in my birthday suit, it will die.  I don't think the sub floor can take the stress, and the basement is a long ways down.  The yak flu does not scare me, either.
I didn't say I was the official "Cat Scratcher".  I said I was the official "Cat Neutering Service" but you managed to hack into the profile and change it.
I don't know what an official cat scratcher does, but its better than being the cat tickler.
Ben W.
  • KennyP and Cat385B have said thanks
#10 Cat385B ONLINE
    HAZMAT CAT
  • 13,780 Thanks
  • 9,919 posts
Posted November 10, 2014 - 10:23 PM
Ben W.
:bigrofl:  :bigrofl: :bigrofl:  :worship:
  • superaben said thank you
#11 Cat385B ONLINE
    HAZMAT CAT
  • 13,780 Thanks
  • 9,919 posts
Posted November 10, 2014 - 10:25 PM
Thanks, Chuck. Sounds like I should try to make an appointment at the tire shop.
#12 Cat385B ONLINE
    HAZMAT CAT
  • 13,780 Thanks
  • 9,919 posts
Posted November 11, 2014 - 09:05 PM
Picked up the rims and tires after work tonight. Great seller, he has five Bolens tube frames and an Ingersoll 4018.
He had three Bolens at his place in town, where we met. A 1050, with a blower and cab. An H14, that has a plow on it, and a G14 that is used for tilling. He also has another single stage snowblower, a mower deck, a front mount reel mower, and a very nice sickle mower for the tubeframes. I really needed to get going, but he was nice enough to show off the herd so I had to stick around an extra half hour for that.
