Wheel Horse 753 Trans Fluid
3 replies to this topic
#1 Junkyard Dave OFFLINE
Junkyard Dave
  • 4 Thanks
  • 3 posts
Posted November 09, 2014 - 03:02 PM
I have a Wheel Horse 753 and want to change the trans fluid. I don't have a manual and would like to know what type of fluid and how much? Thanks
#2 LilysDad OFFLINE
LilysDad
    Millennium Falcon
  • 13,857 Thanks
  • 10,036 posts
Posted November 09, 2014 - 03:40 PM
I would use 110 rearend lube
  • GlenPettit and Junkyard Dave have said thanks
#3 JakeKuhn ONLINE
JakeKuhn
    Wheel Horse Addict
  • 186 Thanks
  • 268 posts
Posted November 09, 2014 - 04:20 PM
Most guys including me use 80/90. To fill it, make sure the tractor is sitting level, and you remove the plug on the left side and fill until it runs out of there There is a drain on the bottom of the trans that should be a allen head.
  • Junkyard Dave said thank you
#4 GlenPettit OFFLINE
GlenPettit
  • 520 Thanks
  • 143 posts
Posted November 09, 2014 - 06:33 PM
For your 753, the official WH Lubrication Usage Charts recommends:      (1963)
Transmission  --  11/2 qts  SAE 90–140 API Service GL-5 Gear Lube
  • LilysDad said thank you
