Early Jacobsen.
9 replies to this topic
#1 TomLGT195 OFFLINE
TomLGT195
  • 3,833 Thanks
  • 2,816 posts
Posted November 08, 2014 - 09:18 PM
I'm going to look at this on sun.
http://westernmass.c...4748521789.html
Anything I should be concerned with? Anything look wrong ? From what I've read so far ( here on GT talk) this has the rare/ hard to find hydraulic lift? What year? I think pre 65
Edited by TomLGT195, November 08, 2014 - 09:19 PM.
  • rustyoldjunk, boyscout862 and Rock farmer have said thanks
#2 Bill56 OFFLINE
  • 840 Thanks
  • 2,179 posts
Posted November 09, 2014 - 02:59 AM
Don't know a lot about the tractor but, sounds like a good price considering the hydraulic lift.
  • boyscout862 and TomLGT195 have said thanks
#3 KennyP ONLINE
  • 38,417 Thanks
  • 45,945 posts
Posted November 09, 2014 - 07:10 AM
It's probably 66-68 model with the Hyd. lift. I see the tag is still at the bottom of the dash. If it runs like he says, I'd buy it!
#4 Oldford OFFLINE
Oldford
  • 1,134 Thanks
  • 786 posts
Posted November 09, 2014 - 07:49 AM
Check the rear hubs aren't loose.  Pull/push tire tops, watch for wobble at hubs.  Steering wheel & floor boards look like 66-down some of them had just 1 set screw holding the hub to the axle.  Later ones had the same hokey hub attachment just had 2 set screws per hub.  Looks like a lot of weight on the wheels, digging puts a strain on the hubs.  If they are loose can tear up the axle ends.  Finding new hubs also a challenge
Hydro lift hard to find may be hard to find seals, would help to have hydro shop nearby.
Blade is lightweight snow blade not heavier dozer no trip springs
Missing pto try to negotiate that
Check tank for rust at least add a fuel filter.  Check motor for metallic sounds at idle, good luck
  • Bill56 and TomLGT195 have said thanks
#5 HANKG OFFLINE
HANKG
  • 6,320 Thanks
  • 3,425 posts
Posted November 09, 2014 - 09:37 AM
I'm thinking 1964 at any rate it would look great restored rear fenders are cool.
  • TomLGT195 said thank you
#6 VintageIronCollector OFFLINE
    Immersed in Tractors
  • 1,424 Thanks
  • 1,856 posts
Posted November 09, 2014 - 10:26 AM
It's not a 66-68. They had the serial number tag on the lower left side of the grill. I'd say its a 64-63?
  • KennyP and TomLGT195 have said thanks
#7 fxdb96 OFFLINE
fxdb96
  • 118 Thanks
  • 105 posts
Posted November 09, 2014 - 06:23 PM
10 HP kohler?  Might have the 1st generation LP head?
#8 josh deaven OFFLINE
josh deaven
  • 479 Thanks
  • 574 posts
Posted November 11, 2014 - 06:39 PM
It is a 1964 model year!
  • TomLGT195 and VintageIronCollector have said thanks
#9 Rock farmer ONLINE
Rock farmer
  • 1,198 Thanks
  • 1,234 posts
Posted November 15, 2014 - 07:46 AM
So, what happened?
Did You buy. It?
#10 TomLGT195 OFFLINE
TomLGT195
  • 3,833 Thanks
  • 2,816 posts
Posted November 17, 2014 - 07:32 AM
No I did not.
I am going to hold out for a complete tractor, something with fewer missing parts. Maybe just a repaint and some TLC.
  • Rock farmer and Oldford have said thanks
