I Went & Done It --- Jd 40S!
82 replies to this topic
#46 grnspot110 ONLINE
grnspot110
  • 4,270 Thanks
  • 2,677 posts
Posted January 05, 2015 - 06:22 PM
Some assembly done today:  HPIM1455.JPG  Just painted the brace from the top link to the frame. Still need to make a parking stand, picked up the metal for that this morning.
  • Gtractor and StevenPa have said thanks
#47 grnspot110 ONLINE
grnspot110
  • 4,270 Thanks
  • 2,677 posts
Posted January 09, 2015 - 04:03 PM
Finished up the 3-pt plow, except for the new share, cover board & decals:  HPIM1458.JPG  HPIM1457.JPG
When the parts show up, I'll put it back in the shop overnight to warm up for the decals, then store it in the back shed until spring.
It's nice to have a loader to move stuff around!   :D
  • Gtractor and KennyP have said thanks
#48 KennyP ONLINE
  • 40,012 Thanks
  • 46,722 posts
Posted January 09, 2015 - 04:36 PM
Good looking plow!
  • grnspot110 said thank you
#49 grnspot110 ONLINE
grnspot110
  • 4,270 Thanks
  • 2,677 posts
Posted March 21, 2015 - 05:06 PM
Never really liked the color of the Ford blade I found for the little 40, so it changed today.  HPIM1541.JPG
First time it's warmed up enough to paint outside since I bought it last fall.  So, this morning, I lightly sanded it, then, after noon I wiped it down with liquid sander.  Gave it five coats of Rustoleum "John Deere Green", the last two with hardener:  HPIM1556.JPG
Hopefully, I can get it put back together & stored in the back shed tomorrow!
  • Gtractor said thank you
#50 grnspot110 ONLINE
grnspot110
  • 4,270 Thanks
  • 2,677 posts
Posted March 22, 2015 - 04:37 PM
Put the blade back together this morning, pivot bolts in first:  HPIM1557.JPG
 Then the springs:  HPIM1558.JPG
I even put the original Ford serial number tag back on:  HPIM1559.JPG
Finished up:  HPIM1560.JPG
Used the 790 w/300 loader to take it to the back shed for storage until next snow season:  HPIM1561.JPG
Slow & easy:  HPIM1562.JPG
Had to re-hook to get it through the shed door:  HPIM1563.JPG
  • olcowhand, Gtractor and js5020 have said thanks
#51 KennyP ONLINE
  • 40,012 Thanks
  • 46,722 posts
Posted March 22, 2015 - 06:33 PM
Your tractor will be green with envy!
#52 JohnDeere110 OFFLINE
JohnDeere110
  • 216 Thanks
  • 92 posts
Posted May 05, 2015 - 03:47 PM
Wow, looks awesome! :thumbs:
#53 grnspot110 ONLINE
grnspot110
  • 4,270 Thanks
  • 2,677 posts
Posted May 16, 2015 - 06:51 PM
Well, today was the day that I finally got started on the little 40S.  Took the oil pan off to clean the sludge out of it, when I changed the oil shortly after buying it, I had to poke a stick through the sludge to drain the oil!   HPIM1667.JPG
Got a pleasant surprise when I took the hood & grille off, new radiator!  HPIM1668.JPG
Took the gas tank off to paint separately.  Even got the battery tray off without twisting any bolts off!  HPIM1669.JPG
  • Gtractor and js5020 have said thanks
#54 grnspot110 ONLINE
grnspot110
  • 4,270 Thanks
  • 2,677 posts
Posted May 18, 2015 - 04:45 PM
Working on the 40 again today, taking parts off for painting:  HPIM1672.JPG  HPIM1673.JPG  HPIM1674.JPG
Went over it with engine degreaser, pressure washed it, then "Simple Green" & another pressure wash.  I'll need to wire brush some areas before going over it with liquid sander then primer.  Hope to spray some "Classic Green" by the end of the week!
  • Gtractor, js5020 and superspeedex have said thanks
#55 KennyP ONLINE
  • 40,012 Thanks
  • 46,722 posts
Posted May 18, 2015 - 06:16 PM
The poor thing! All naked and cold!
#56 grnspot110 ONLINE
grnspot110
  • 4,270 Thanks
  • 2,677 posts
Posted May 21, 2015 - 09:54 AM
  • Trav1s and js5020 have said thanks
#57 grnspot110 ONLINE
grnspot110
  • 4,270 Thanks
  • 2,677 posts
Posted May 21, 2015 - 04:53 PM
Put four double coats of JD "Classic Green": HPIM1677.JPG  HPIM1678.JPG  HPIM1679.JPG
Hopefully, I can get the wheels finished tomorrow!  The aren't going to take a lot, clean them up & one coat of JD "Yellow".
  • js5020 said thank you
#58 KennyP ONLINE
  • 40,012 Thanks
  • 46,722 posts
Posted May 21, 2015 - 07:01 PM
Put a blanket over that poor thing. It looks cold from here!
Great job, Lowell!
#59 grnspot110 ONLINE
grnspot110
  • 4,270 Thanks
  • 2,677 posts
Posted May 22, 2015 - 05:26 PM
Ordered new front tires for it.  Parts order from Steiner Tractor came today, which included a new water pipe, painted it & the air cleaner.  Start putting it all back together tomorrow!
#60 grnspot110 ONLINE
grnspot110
  • 4,270 Thanks
  • 2,677 posts
Posted May 23, 2015 - 05:27 PM
