Torqe Spec Bering Plate
1 reply to this topic
#1 bill3t OFFLINE
bill3t
  • 59 Thanks
  • 105 posts
Posted November 08, 2014 - 07:13 PM
im puting my 14hp kohler back together and didnt see a torq listing in my manuel. anybody have it thanks bill
#2 EricFromPa ONLINE
EricFromPa
  • 4,156 Thanks
  • 3,344 posts
Posted November 08, 2014 - 08:01 PM
I put mine to 20 ft lb then 25 ft lb then to 30 ft lb.Give it a couple minutes between step torquing.It will squish the seal and shims and it needs time to settle.That way you don't warp the bearing plate and cause an unwanted oil leak.
I put both the Bearing plate and Oil pan bolts to 30 ft lb.It felt good there.
My book shows 35 ft lb on the Bearing plate and Oil pan.
I did put 1 that I had here at 35 and it started to pull the lock washer into the aluminum.I've never had 1 loosen up or leak at 30 ft lb.
Edited by EricFromPa, November 08, 2014 - 08:02 PM.
  • bill3t said thank you
