What To Use For An Axle Build?
10 replies to this topic
  • 2,325 Thanks
  • 1,496 posts
Posted November 07, 2014 - 09:51 PM
The Waterloo 15 that I restored last winter needs a new axle: it is seriously grooved (and leaking) at the oil seal.  I had one made for the Supremacy 45, but that cost $240.  Thought I might take a whack at making one.  The biggest question is: cold rolled round rod or hardened steel?  The tractor is less than 250 lbs.  The axle is 26.5" long & 1" diameter.  It rides in bronze bushings.  What say yea all?
#2 MH81 OFFLINE
Posted November 07, 2014 - 11:59 PM
Is it possible to weld up the worn and turn it back down?
#3 gopher OFFLINE
gopher
  • 750 Thanks
  • 753 posts
Posted November 08, 2014 - 12:04 AM
I'd go with cold rolled or annealed cold rolled should last for the price.Hardened steel lacks machine ability for average guys shop.unless the axle extends way past the bushings shouldn't need extremely hard bar stock.
#4 Mike Unwin OFFLINE
Mike Unwin
  • 403 Thanks
  • 303 posts
Posted November 08, 2014 - 08:34 AM
It would be nice to keep it original and it is likely cheaper like MH81 said to weld or even use JB Weld in the grooves and machine it. Sometimes you can find Speedi sleeves to repair worn shafts or John Deers Corn Head grease. Cheers Mike
  • New.Canadian.DB.Owner and Sawdust have said thanks
#5 Alc OFFLINE
  • 6,739 Thanks
  • 7,395 posts
Posted November 08, 2014 - 08:42 AM
If it's just the seal leaking where the grooves are I would look for a little wider seal so it rid es on a good section of the axle . Say the original seal is .250 wide maybe one .375 would work,
Edited by Alc, November 08, 2014 - 08:43 AM.
#6 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted November 08, 2014 - 01:08 PM
I know they make "repair"bearings and seals for autos,they ride in a different area than OEM
#7 New.Canadian.DB.Owner OFFLINE
  • 2,325 Thanks
  • 1,496 posts
Posted November 08, 2014 - 03:54 PM
Thanks for the suggestions.  I think I will go with some 1018 cold rolled.  A Speedi Sleeve won't work: the groove is 1/2" wide and the sleeve is only .313" wide and $60.  Similar problem for a wider seal.  I could weld & turn it, if I had the skill & a lathe, but I have neither.  The best option seems to be a new axle.
#8 Alc OFFLINE
  • 6,739 Thanks
  • 7,395 posts
Posted November 08, 2014 - 05:11 PM
1/2" wide! How deep is it ?
#9 New.Canadian.DB.Owner OFFLINE
  • 2,325 Thanks
  • 1,496 posts
Posted November 09, 2014 - 03:59 PM
The axle measures about 0.998" in the good spots, and 0.975" in the groove.  Guess that makes it about 0.012" deep.
#10 Alc OFFLINE
  • 6,739 Thanks
  • 7,395 posts
Posted November 09, 2014 - 05:03 PM
Galock carries some oil seals for shafts .969 it might be worth your effort to try polishing the shaft and try one of theses if you can match the OD of the seal. It would mean stretching the seal until it was in the correct section . They also carry .984 too I'm sure other co. Sell ones in those sizes.
#11 canadiantriumphtr8 OFFLINE
canadiantriumphtr8
  • 3 Thanks
  • 2 posts
Posted December 07, 2014 - 08:12 PM
I had a similar problem on a harmonic balancer on a crank shaft , Ford 460 engine, where the seal rode on the balancer.
Made a nice groove and no speedi sleeve would work.
I found a place that did hard chroming. What they did was cylindrically grind the groove out, say .020 thou and then hard chrome that area and regrind back down to oem spec.
Seems the hard chrome wore better and had better oil retention, still working to this day.
Cost me about $ 50.00 CAD back in 1998 in Toronto.
  • limebuzz, MH81 and New.Canadian.DB.Owner have said thanks
