Ford 120 Hydro Fluid
2 replies to this topic
#1 Bob IN OFFLINE
Bob IN
  • 1,477 Thanks
  • 676 posts
Posted November 07, 2014 - 06:03 PM
I have a ford 120 open side. I haven't had it very long. I need to know what kind of fluid I should put in it? Tried looking in the manual section but no luck. Maybe I wasn't looking in the right place.
#2 KennyP OFFLINE
  • 40,973 Thanks
  • 47,143 posts
Posted November 07, 2014 - 06:09 PM
If it's the LGT 120, that is a gear drive. The 125 is the hydro. Is it pre '72?
#3 Oldford OFFLINE
Oldford
  • 1,135 Thanks
  • 786 posts
Posted November 08, 2014 - 05:57 AM
If your tractor looks like this, http://gardentractor...p-old-blue-120/ it is called Ford 120 (no "open side" term used pre-72) is supposed to use Type A auto trans fluid which is nla, Dexron 2 is compatible which i believe also crosses with Dex3.  I use it in mine works fine
If it looks like this one, http://gardentractor...s-fluid-change/ it is called Ford LGT "open side," is 72-up, apparently may use hydraulic fluid, good luck
