Dirty Kohler
13 replies to this topic
#1 fxdb96 OFFLINE
fxdb96
  • 118 Thanks
  • 105 posts
Posted November 07, 2014 - 06:23 AM
Carb clean scotch brite and call it good?
  • T Guiles, superspeedex and Bill 76 have said thanks
#2 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,295 Thanks
  • 9,777 posts
Posted November 07, 2014 - 08:10 AM
I don't think I would call all that oil "good".
  • Bill 76 said thank you
#3 Trav1s ONLINE
Trav1s
  • 3,307 Thanks
  • 4,362 posts
Posted November 07, 2014 - 08:54 AM
Not looking good there.  Rings are shot?!?
#4 fxdb96 OFFLINE
fxdb96
  • 118 Thanks
  • 105 posts
Posted November 07, 2014 - 08:56 AM
I think so Trav1s.  Piston looks to be .030 already.. it is marked 30 on top
  • superaben and Bill 76 have said thanks
#5 Trav1s ONLINE
Trav1s
  • 3,307 Thanks
  • 4,362 posts
Posted November 07, 2014 - 09:00 AM
I am afraid it is time for a different engine.  What size is it?
#6 fxdb96 OFFLINE
fxdb96
  • 118 Thanks
  • 105 posts
Posted November 07, 2014 - 09:28 AM
14HP.  I cleaned up all the deposits, i plan on re-assembling and running it for the winter at least.  It only smoked a little.
Maybe ring replacement would take care of it?  I think it was a little heavy on fuel too so that might be some of the wetness.
  • superaben said thank you
#7 fxdb96 OFFLINE
fxdb96
  • 118 Thanks
  • 105 posts
Posted November 07, 2014 - 09:34 AM
Or valve guides?
#8 Gabriel OFFLINE
Gabriel
  • 1,442 Thanks
  • 1,859 posts
Posted November 07, 2014 - 09:56 AM
You could have a sleeve put in to get the cylinder back to factory specifications.
#9 Username OFFLINE
Username
  • 2,072 Thanks
  • 1,425 posts
Posted November 07, 2014 - 10:08 AM
Looks like your head gasket may have been leaking a little.If so,a new gasket might improve performance.
  • JDBrian, Trav1s and superaben have said thanks
#10 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted November 07, 2014 - 11:02 AM
That's what I thought when looking at the left side of the gasket. As long as the cylinder looks good you might as well run it until you can afford to rebuild or replace.
#11 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted November 07, 2014 - 12:48 PM
Looks good to me,just needs a good cleaning.
#12 fxdb96 OFFLINE
fxdb96
  • 118 Thanks
  • 105 posts
Posted November 07, 2014 - 01:24 PM
Well i have a new head gasket, helicoiled spark plug threads, she is all cleaned up. I will let you know what happens soon enough!
  • Trav1s and Auburn David have said thanks
#13 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted November 07, 2014 - 02:50 PM
I have found a leaking head gasket can cause the oily look that is in your photo.
#14 fxdb96 OFFLINE
fxdb96
  • 118 Thanks
  • 105 posts
Posted November 07, 2014 - 05:09 PM
Well i got her all back together.  Still smokes a little.  Mostly when quickly increasing throttle from idle to WOT.  At wide open throttle it smokes sometimes, but not always.  I guess i will see how she does snowblowing this winter and maybe next spring i can pull the motor, sleeve it, valves, guides etc... the works...
  • JDBrian, Bill 76 and Auburn David have said thanks
