Are My Tires Tubeless? 2014 Craftsman G5500
6 replies to this topic
#1 GTjet52 OFFLINE
GTjet52
  • 1 Thanks
  • 2 posts
Posted November 06, 2014 - 08:03 PM
Bought a new GT from Sears a few months back.  I've installed a sleeve hitch and bought a box scraper for my driveway.  I plan on working a garden in the spring and will need AG tires.  Some of the tires i've found on Ebay are tubeless and some are not.  Does my GT have tubes?
#2 Bolens 1000 OFFLINE
  • 14,986 Thanks
  • 18,140 posts
Posted November 06, 2014 - 08:16 PM
Welcome :wave:
Take a look at the valve stems and see.
If your not sure post a picture and we can tell you.
#3 bhts OFFLINE
bhts
  • 1,472 Thanks
  • 2,165 posts
Posted November 06, 2014 - 10:08 PM
You will want a tubeless tire.
#4 PaulL OFFLINE
PaulL
  • 114 Thanks
  • 72 posts
Posted November 07, 2014 - 01:18 AM
Bend the rubber valve stem slightly where it enters the steel wheel.  If there is a lip on the rubber larger in diameter than the hole in the steel wheel it is tubeless.  If it goes through the steel wheel with no lip, it has a tube.
#5 GTjet52 OFFLINE
GTjet52
  • 1 Thanks
  • 2 posts
Posted November 07, 2014 - 03:10 AM
Thanks, ill check.
  • JDBrian said thank you
#6 MH81 OFFLINE
Posted November 07, 2014 - 07:52 AM
I own many tubeless tires with tubes in them. I usually do, even if they're tubeless as an added layer of protection. Especially if I am filling the tires.
#7 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted November 07, 2014 - 11:08 AM
Most likely they are tubeless. If they are not let us know.
