Rube Goldberg Mower Deck
3 replies to this topic
#1 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted November 03, 2014 - 08:59 PM
I have a Ingersoll 6018/Dig-it 188T(as I am sure you all know..I have only posted about it a billion times on here)..anywho I also have a Jacobsen 428d turfcat with a 5ft hydro cutting deck...and the mounts on the deck line up with the loader bucket mounts on the 6018(see where I am going with this yet?)...With the use of quick disconnects I want to be able to remove the loader bucket and install the mower deck..but there is a question on how to feed the hydraulics of said deck..the 6018 has a 2 stage pump(one for motion and one for the buckets and such)Would I need to add another pump?(I have a few I could use..but I would need to find room for another cooler and tank?)..any thoughts on this would be great!!!!
#2 cootertom OFFLINE
cootertom
  • 1,617 Thanks
  • 836 posts
Posted November 03, 2014 - 09:10 PM
Be careful, you may get that look again if you need more hyd. fluid for another cooler.
  • KennyP, tinbender7 and Auburn David have said thanks
#3 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted November 03, 2014 - 09:16 PM
Thats why I asked for 5 gallons :rocker2:
#4 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted November 03, 2014 - 11:40 PM
If you wont need the tilt function while using the mower a couple of diverter valves on the tilt circuit should work "IF" the pump has enough displacement to run the mower.
Mike
  • Auburn David said thank you
