Hydraulic Problem
17 replies to this topic
#16 olcowhand ONLINE
  • 42,898 Thanks
  • 31,941 posts
Posted February 27, 2011 - 07:19 AM
It is possible that your hydro could be getting weak. A poor pump would cause reduced lifting capacity, and slower lifting under load.
That would also cause the tractor to slow down when it hits resistance.
Very true Jim. I once owned a CC that had a worn hydro and as soon as I got to even a slight uphill, it would slow by maybe half to 2/3 of it's speed. The rotors & faceplates were so worn it was leaking lots of pressure under load. This as an MTD Cadet so not worth expense or time to repair. I found another unit. On the older hydro's, you can machine both parts & renew them.
#17 middleageddeere OFFLINE
middleageddeere
    Tacos!
  • 243 Thanks
  • 1,082 posts
Posted February 27, 2011 - 08:16 AM
Ug, that was what I did not want to hear. If I get a different pump, should I buy new?
#18 olcowhand ONLINE
  • 42,898 Thanks
  • 31,941 posts
Posted February 27, 2011 - 09:06 AM
You don't even wanna know how expensive they are new!!! I've bought used with GREAT results, but depends on the seller's honesty. One of my Massey's Sundstrand hydro was shot. I had an old pump for parts & swapped out the worn rotors (faceplate was still good).....she's pushing my FEL today with POWER! I've bought a good 3 complete hydro units, and all worked perfectly.
