Simplicity 5212 No Spark At Plug
simplicity briggs 280700
12 replies to this topic
#1 rojosmith OFFLINE
rojosmith
  • 11 Thanks
  • 7 posts
Posted November 02, 2014 - 10:13 AM
I just purchased a simplicity 5212. It started and ran well when I first brought it home. Now I have no spark at the plug. There are several safety switches on it two that have been bypassed. The seat switch and the neutral switch. Now I'm not sure if the lack spark is from the safety switch fault or an engine fault. I would like to wire the tractor to its simplest form. "Start engine turn off engine. Charge battery." you don't need to tell me this is not safe I understand that.
Next to the starter solenoid there's a small round electrical device that all the safety wires run into. Does anyone know what that's for? How can I test to see if there is a problem between the safety switches and the engine.
  • hamman said thank you
#2 hamman ONLINE
hamman
    Homelite Owner Extraordinaire
  • 5,991 Thanks
  • 2,715 posts
Posted November 02, 2014 - 10:29 AM
Any pictures to see what you are talking about. I would jump out all safety switches to start with. Not take them out of line but for the sake of testing just jump them out. Start with one at a time and maybe that would eliminate one or the other. Also check your ignition switch. Might be as simple as that.  Just a guess.      Roger.
  • rojosmith said thank you
#3 rojosmith OFFLINE
rojosmith
  • 11 Thanks
  • 7 posts
Posted November 02, 2014 - 11:03 AM
thanks for reply. I think I have determined that the safety switches simply prevent the engine from cranking. still not sure though.I took a picture but I haven't figured out how to post it yet. I'll definitely try the starter switch to see if there's something wrong there. I guess there must be something in the switch that would ground out,,,,, possibly the coil,,,,, is that correct?
#4 Auburn David OFFLINE
Auburn David
  • 2,754 Thanks
  • 1,962 posts
Posted November 02, 2014 - 11:22 AM
Do you have 12v going to the coil?does it have points/condenser?
  • hamman and rojosmith have said thanks
#5 Auburn David OFFLINE
Auburn David
  • 2,754 Thanks
  • 1,962 posts
Posted November 02, 2014 - 11:24 AM
some safety switches (as in the one on the seat)will keep it from firing as well.
#6 rojosmith OFFLINE
rojosmith
  • 11 Thanks
  • 7 posts
Posted November 02, 2014 - 12:25 PM
thank you as well Auburn. My maintenance manual for the engine doesn't reference points or condenser. I tested the switch with a multimeter it seems to be ok, that is with my limited knowledge. This is so frustrating? 3 weeks ago it started and ran fine. I'm fairly certain it's something simple that I'm overlooking. I'll check those things you suggested and then get back with you.
Edited by rojosmith, November 02, 2014 - 12:26 PM.
  • hamman and Auburn David have said thanks
#7 rojosmith OFFLINE
rojosmith
  • 11 Thanks
  • 7 posts
Posted November 02, 2014 - 12:54 PM
Boy do I feel stupid now. I think I found my problem. I wish I could upload the picture I took. I took the cover off of the cooling fins above the coil and found that a mouse had made a nest inside my engine grounding out the coil.
  • Alc, boyscout862 and Auburn David have said thanks
#8 KennyP ONLINE
  • 32,253 Thanks
  • 42,033 posts
Posted November 02, 2014 - 12:58 PM
Are you using a phone to post or a computer? A link to pic uploading is at the bottom of this post!
  • Auburn David and rojosmith have said thanks
#9 rojosmith OFFLINE
rojosmith
  • 11 Thanks
  • 7 posts
Posted November 02, 2014 - 02:21 PM
I'm using a tablet to do my by posting. The Samsung Galaxy.
#10 rojosmith OFFLINE
rojosmith
  • 11 Thanks
  • 7 posts
Posted November 02, 2014 - 02:25 PM
Well I thought for sure that was the smoking gun. But its not. I do have spark at the plug now but still no start.
#11 boyscout862 ONLINE
  • 10,798 Thanks
  • 8,085 posts
Posted November 02, 2014 - 02:36 PM
Mice love the old B&S engines. I found several nests and a snake skin in a 23D this summer. Good Luck, Rick
#12 rojosmith OFFLINE
rojosmith
  • 11 Thanks
  • 7 posts
Posted November 02, 2014 - 05:25 PM
Thank you all for the help. Problem solved! When I took the cowling off earlier and find the nest I assume that was the problem. After putting it back together, I got a mild spark but the engine still wouldn't run. Taking off the shroud again I and found that the mouse had chewed through the spark plug wire insulation. I taped it up put it back together. Runs fine!!!! Again, thank you all for the help.
  • Alc, KennyP, boyscout862 and 1 other said thanks
#13 KennyP ONLINE
  • 32,253 Thanks
  • 42,033 posts
Posted November 02, 2014 - 05:41 PM
Glad you got it running!
  • Auburn David said thank you
