Just In Case
5 replies to this topic
#1 HANKG ONLINE
HANKG
  • 6,320 Thanks
  • 3,426 posts
Posted November 02, 2014 - 09:49 AM
I have been wanting a case 100 series for quite sometime and after a long and arduous search I found this 1968 155 in N.C. and had it shipped to NJ. It came with wheel weights a deck and the optional hydraulic lift it also has disk brakes lending weight to it being a 1968. There are however, a couple of things I question such as its K301 should be a K241 and as you can see in the picture someone zulued the arm to the 3 point I would sure like to know what that arm is supposed to look like. I can get over the K 301 but not the arm bar any help would be greatly appreciated thanks HANK.IMG_0885.JPG IMG_0886.JPG IMG_0887.JPG IMG_0889.JPG IMG_0890.JPG IMG_0888.JPG
  • Alc and hamman have said thanks
#2 petrj6 OFFLINE
petrj6
  • 4,083 Thanks
  • 2,369 posts
Posted November 02, 2014 - 10:31 AM
   I have a case 155 out back, I will go and take some pics of the 3pt arm you are talking about, that one is definitely fubar.  it should go under the tractor seat next to the rear end.  I will get pics later today or tomorrow.  Is that lift guage original?  it looks like it may be or it was made well.  either way it is a good idea.
                                                            Pete
Edited by petrj6, November 02, 2014 - 10:32 AM.
  • HANKG said thank you
#3 HANKG ONLINE
HANKG
  • 6,320 Thanks
  • 3,426 posts
Posted November 02, 2014 - 11:11 AM
I don't know if the gauge is original but I think it may be unless someone had a brain storm.
#4 petrj6 OFFLINE
petrj6
  • 4,083 Thanks
  • 2,369 posts
Posted November 02, 2014 - 04:19 PM
    OK I went out back and took some pics but they are not the greatest.  sorry about that.  Later in the week I will go out and take the bar out, I can either re-pop it for you for a little $$$  Or if you have the stuff I will just make a print of it and you can make it yourself.  It looks to be just a 1-1/4" wide by 1/4" thick bar bent in the rite way with a  pin welded to one end and a slot in the other.   let me know.
        Pete
#5 petrj6 OFFLINE
petrj6
  • 4,083 Thanks
  • 2,369 posts
Posted November 02, 2014 - 04:21 PM
   After looking at your pics it seems they may have been using that setup for down pressure, the setup I have looks to be original and was only used to pick up the attachments not for down pressure.
                                                          Pete
#6 jabelman OFFLINE
jabelman
  • 2,231 Thanks
  • 1,596 posts
Posted November 02, 2014 - 04:47 PM
Nice score!
