Looks good! Didn't know the Hi/Lo was adjustable! Cool!
Old Girl 1978 Roper
#91
OFFLINE
Posted November 23, 2014 - 04:18 PM
#92
OFFLINE
#93
OFFLINE
Posted November 23, 2014 - 11:28 PM
SWEET RIDE MINES MODEL # 7162080 HOPE SOMEONE KNOWS WHAT YEAR MINE IS WITH ONAN BOUGHT FOR 90 DROPPED VALVE SEAT MIGHT STREACH PUT P24 IN IT AGAIN SWEET RIDE
- larrybl said thank you
#94
OFFLINE
Posted November 25, 2014 - 10:28 PM
Still working on the transaxle, everything is going well, although I was wondering why the shifter lever was tight and sticking. I pulled it off and found gobs of rust and crud. Doesn't look like it got through the rubber boot. I am cleaning this up and will add grease to it before I re-install the boot.
The main plan for now is to complete the transaxle, frame, and front axle and order new tires. This should make a rolling frame.
I also bought new mufflers, but need to figure out the mounting, That will come later when I get to the Engine. The transaxle is looking good, but I'll hold off on pictures till I am done with it. Maybe tomorrow.
- MH81, Sawdust and Gabriel have said thanks
#95
OFFLINE
Posted November 25, 2014 - 11:11 PM
Those mufflers will be louder, that s for sure.
Guys, do these Onan's have any tendencies for loosening exhaust seats without the mufflers for cooling buffers? Just want to ask before Larry mounts them on.
- larrybl and wvbuzzmaster have said thanks
#96
OFFLINE
Posted November 26, 2014 - 04:40 AM
Alan, I have those mufflers on the B48 on Big Bertha. They are very noisy. No other issues with them, though. Not sure on the 'big blocks'.
- MH81 said thank you
#97
OFFLINE
Posted November 26, 2014 - 11:10 PM
It will be a while before I get to the engine. Mufflers will need replaced, I am open to better options.
#98
OFFLINE
Posted November 26, 2014 - 11:38 PM
Edited by Sawdust, November 26, 2014 - 11:38 PM.
#99
OFFLINE
Posted November 27, 2014 - 12:11 AM
Hi you might check on ebay there are a number of Onan mufflers listed, there are generally some on all the time, most are the single can type that's what's on my SS16 and its fairly quiet lots more than the ST16.
#100
OFFLINE
Posted November 27, 2014 - 11:23 AM
I checked Ebay and mostly the single can type, not sure about (fitment) with these (including with the hood installed).MH81, I don't plan on a "no muffler plan" These are the largest I could find so far (9-16 hp) each that I am pretty sure I can modify to work. The plan is to cut the old can's off and weld NPT threaded pipe fitting to the end of the pipe and try and keep the new muffler within the same general vicinity and angle as the old can. These mufflers are approximately 1/2 the size of the old cans, I'll try another search and see what I can find.
- MH81, KennyP and Gabriel have said thanks
#101
OFFLINE
Posted November 27, 2014 - 07:22 PM
Here is a teaser for the transaxle, I re-lined the brake band today and finished touching up a few other items on the transaxle. Once I install the brake band (after the JB hardens) I'll post the completed unit. The steps to reline the band.
1. drill out the old lining rivets (the old lining was ok, but only 1/2 as thick as the new)
2. used the old lining to measure and cut the new lining.
3. small dremel to grind off the old adhesive.
4. masking and paint optional
6. pre-fit lining and make sure enough clamps are on hand.
7. mix 1/3 - 1/2 tube of JB.
8. Clamp, and wipe off excess.
- MH81 and Gabriel have said thanks
#102
OFFLINE
#103
OFFLINE
Posted November 28, 2014 - 09:34 AM
That's looking real good, Larry!
- Gabriel said thank you
#104
OFFLINE
Posted November 28, 2014 - 10:58 AM
Your transmission looks nice! Thanks for the pictures!
Edited by Gabriel, November 28, 2014 - 10:59 AM.
