Old Girl 1978 Roper
968 replies to this topic
#796 UncleWillie OFFLINE
  • 15,663 Thanks
  • 8,758 posts
Posted July 25, 2015 - 08:59 AM
Just slather the whole engine in Permatex. problem solved.
  • larrybl and KennyP have said thanks
#797 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,980 Thanks
  • 4,409 posts
Posted July 25, 2015 - 09:12 AM
Moving to another topic for now. The heat shield material came in. It is 18" X 18", adhesive backed, and seems a good thickness. I plan on lining the inside of the hood above the muffler with this.
#798 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,980 Thanks
  • 4,409 posts
Posted July 25, 2015 - 02:49 PM
Here is the heat shield installed. this stuff is really easy to work with and looks like it will work a treat.
#799 MH81 OFFLINE
Posted July 25, 2015 - 02:55 PM
@^$%#$ Re-Torque ---- Re-Peat, Starting to get pi$$ with this.
I can see it now.
Onan engine for sale... Cheap.
Friggin thing won't stop leaking
Local pickup only, it's laying on its side in front of my garage
That's where it landed when I got peeved, lost my cool and threw it.
As is, where is.
  • larrybl, Alc and wvbuzzmaster have said thanks
#800 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,980 Thanks
  • 4,409 posts
Posted July 25, 2015 - 02:57 PM
Mr. Onan is sending me another gasket next week with some install tips. I am helping the Neighbor with his 2005 Murray for now.
#801 UncleWillie OFFLINE
  • 15,663 Thanks
  • 8,758 posts
Posted July 25, 2015 - 06:03 PM
I see a second GTT tractor named Hemorrhoid
  • larrybl, MH81 and KennyP have said thanks
#802 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,980 Thanks
  • 4,409 posts
Posted July 29, 2015 - 09:32 PM
The pan gasket is in transit, but the discussion over there revolved around where the 3" bolts came from. The manual miss stated the correct pan bolt size and it was determined these are 2-1/2 in length. The manual indicated 3" bolts for the intake manifold. I pulled one and it is 2-1/2 so I may have accidently swapped these on re-assembly. The plan now is to get the new gasket and check for 24 hours to see if the leak is fixed. Replace the manifold bolts (one at a time) with 3" bolts. If the leak is fixed, Drain the oil, put on a new $18.00 oil filter and hopefully call this good.
#803 KennyP ONLINE
  • 38,267 Thanks
  • 45,876 posts
Posted July 30, 2015 - 04:41 AM
I hope this cures the leak!
  • larrybl and MH81 have said thanks
#804 MH81 OFFLINE
Posted July 30, 2015 - 12:03 PM
Boy, I hope all goes as planned.
  • larrybl and wvbuzzmaster have said thanks
#805 UncleWillie OFFLINE
  • 15,663 Thanks
  • 8,758 posts
Posted July 30, 2015 - 02:04 PM
A differently bolt can sure cause a sealing problem
  • larrybl said thank you
#806 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,980 Thanks
  • 4,409 posts
Posted July 30, 2015 - 06:56 PM
New pan gasket is installed with 2-1/2" bolts and torqued to 30fp
New filter and oil installed.
Intake bolts replaced with 3" bolts and torqued to 20fp.
Now to let it set on the towel till tomorrow.
  • MH81, Alc and KennyP have said thanks
#807 KennyP ONLINE
  • 38,267 Thanks
  • 45,876 posts
Posted July 30, 2015 - 06:58 PM
Good luck!
#808 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,980 Thanks
  • 4,409 posts
Posted July 31, 2015 - 08:19 PM
Success! looks like the forth or fifth time was the charm. Now to put her back together.
#809 jhn9840 OFFLINE
jhn9840
  • 373 Thanks
  • 354 posts
Posted July 31, 2015 - 09:09 PM
Congratulations, that is one very fine tractor. Glad you stuck with it to figure out her issue.
jhn9840
John
#810 KennyP ONLINE
  • 38,267 Thanks
  • 45,876 posts
Posted August 01, 2015 - 05:53 AM
:dancingbanana: :dancingbanana: :dancingbanana:  Glad it's house broke!
