Old Girl 1978 Roper
976 replies to this topic
#571 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,640 Thanks
  • 4,638 posts
Posted May 14, 2015 - 10:03 PM
Waiting to see if the fabricators have any suggestions. The way it is right now there is no way it will work.
#572 KennyP ONLINE
  • 41,448 Thanks
  • 47,379 posts
Posted May 15, 2015 - 04:53 AM
Sorry that didn't work out for you. Hope you can get something figured out.
  • larrybl said thank you
#573 MH81 OFFLINE
  • 29,979 Thanks
Posted May 15, 2015 - 06:41 AM
Sorry to hear that you're having problems.
Almost looks like the box itself is to deep.
Is there any way for them to thin it down?
Keep in mind that only rarely do prototypes not need at least some tweaking.
Good luck.
  • larrybl and wvbuzzmaster have said thanks
#574 Georgia SS OFFLINE
Georgia SS
  • 46 Thanks
  • 34 posts
Posted May 15, 2015 - 09:25 AM
HI Larry have been folloing your project from start, had problems registering to offer suggestions, so will see if this works, i have twenty restored sears from ST12 to GT19.9, the muffler thing is not good. I found a set of 19.9 mufflers on Ebay a while back so they are out there. At this point if you are accepting suggestions i saw in one of the photos, you have the clutch operating rod upside down, the long end goes down for the belt to lay on, I also use a short length of a.c.hose on the end that support the belt while clutch is pressed down, seems to help stop belt from moving for shifting. I don't know how to find private Emails.
Hang In There
Jimmy
In South Georgia USA
  • larrybl, MH81 and KennyP have said thanks
#575 KennyP ONLINE
  • 41,448 Thanks
  • 47,379 posts
Posted May 15, 2015 - 09:44 AM
Hang In There
Jimmy
:wave: Welcome to the forum! The PM system is at the top right, a small envelope next to your user name.
#576 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,640 Thanks
  • 4,638 posts
Posted May 15, 2015 - 12:39 PM
Thanks Georgia SS, I'll double check the clutch rod. Couple questions.
1. Do you think I can modify these to fit? http://www.ebay.com/... 24hp &_sacat=0
2. Is there a part number for these so I might see if some in better shape are available.
#577 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,640 Thanks
  • 4,638 posts
Posted May 15, 2015 - 02:06 PM
I have searched hi and low for a muffler(s) that I could use, I see some JD mufflers that might work, and looked at many others. I even looked at a SS hood (the metal part that I could cut the side out of so the hood would close. My main issue now is they re-used my manifold pipes, so to do anything I would need to cut them off. Another option would be to order new exhaust manifold adapters (154-1484-50) for $50.00 and start over going back to NPT pipe fittings and pepper shakers which I still have.
#578 KennyP ONLINE
  • 41,448 Thanks
  • 47,379 posts
Posted May 15, 2015 - 03:26 PM
Only thing about those mufflers, they are both 'right' or 'left'. One should be opposite the other.
#579 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,640 Thanks
  • 4,638 posts
Posted May 15, 2015 - 05:11 PM
Yea I saw that. I went ahead and ordered two 154-1484-50 Exaust manifold adapters, to see what I can do with NTP pipe and pepper shakers. Know anyone that would be interested in a N52M muffler that is too big?
#580 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,640 Thanks
  • 4,638 posts
Posted May 15, 2015 - 06:55 PM
I am working on engine assembly now, taking my time on it. Also doing some detail work.
Red and Hulk II have caps over their steering spindles. Since I needed to order some steering bushings for RED, I orders a couple spindle caps. The retaining washer was too small to hold the cap on, so I found a couple larger washers, quick change out and the caps fit like a charm. Feels good to have something work right for once.
  • MH81, KennyP and UncleWillie have said thanks
#581 KennyP ONLINE
  • 41,448 Thanks
  • 47,379 posts
Posted May 15, 2015 - 07:05 PM
Nice addition to it!
#582 MH81 OFFLINE
  • 29,979 Thanks
Posted May 15, 2015 - 08:03 PM
Those will help keep the grit out and dress it up nice.
If you need detail pics and measurements on a 19.9 muffler set, please let me know. I'll do the best I can.
I know it's disheartening, but can you take the muffler back and see if they can make it fit? Did they have any ideas?
#583 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,640 Thanks
  • 4,638 posts
Posted May 15, 2015 - 08:10 PM
A detail of the originals may help with my next venture. I think the CraftMasters design is flawed "Square". I did discuss with them of installing a clamp on the muffler to manifold pipe so I could slide the box in or out some. I don't think this would have helped as the muffler needs to be tilted 10* down. If it was round, and I had adjustment clamps it might have worked.
#584 MH81 OFFLINE
  • 29,979 Thanks
Posted May 15, 2015 - 08:15 PM
I wonder if they could shorten the one pipe at the manifold to get the 10 degrees?
  • wvbuzzmaster said thank you
#585 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,640 Thanks
  • 4,638 posts
Posted May 15, 2015 - 08:39 PM
It needs to go back 1-1/2" and rotate 10* The Airfilter and dipstick won't allow that.
