Old Girl 1978 Roper
968 replies to this topic
#241 KennyP ONLINE
  • 38,267 Thanks
  • 45,876 posts
Posted January 22, 2015 - 05:10 AM
Good catch on that, Larry. Not sure if it is of much consequence, though.
#242 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,980 Thanks
  • 4,409 posts
Posted January 22, 2015 - 10:20 PM
Been looking over the wiring, I think I found a good alternate to the safety switches (Sears P/N 104445X at $7.01 each). I have a good implement switch, connectors are on order along with the light switch and Solenoid. I'll check around the shop this weekend for better looking wire, or pick some up locally. Overall the wire harness should be easy. For hind sight, I wish I had taken higher rez and more pictures on how the clutch assembly went together, but it was broken when I got her. Also a few more pictures on the left side would have been helpful, but I think I can figure it all out from the manuals. Good news, I did find a complete set of Sears rims from a GT-16 that I forgot I parted out a few years ago. I can sand and paint them and take my time removing the tires from the original rims. I have to change radiator hoses on my Daughters car this weekend, but I hope to make some more progress with the Old Girl too. I plan on a couple stops tomorrow to see if I can find a small idler pulley, and a clutch brass bearing before jumping on-line for these.
#243 KennyP ONLINE
  • 38,267 Thanks
  • 45,876 posts
Posted January 23, 2015 - 07:05 AM
Is the part # you posted for the alternate switch or the original?
  • larrybl said thank you
#244 MH81 OFFLINE
Posted January 23, 2015 - 07:23 AM
Larry, I do know Bolens1000 has the clutch idler pullies for these.
Nice find on sensor switch.
  • larrybl and wvbuzzmaster have said thanks
#245 TAHOE ONLINE
TAHOE
  • 7,964 Thanks
  • 5,672 posts
Posted January 23, 2015 - 08:27 AM
I am pretty sure one of us can get you clutch pics if you need them.
#246 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,980 Thanks
  • 4,409 posts
Posted January 23, 2015 - 10:36 AM
The safety switch PN is from my other Craftsman, and still available. The orginal switch is a all metal can and round in shape, the alternate is plastic and square, but will bolt up and line up without any modifications.
#247 Gabriel OFFLINE
Gabriel
  • 1,442 Thanks
  • 1,859 posts
Posted January 24, 2015 - 11:02 PM
The deck is done, and tested and stored. Had to use a come-along to get it back up there. It is secured with two cargo straps and a nylon rope. The deck will stay there until the Old Girl is ready.
https://www.youtube....eature=youtu.be
Nice job!
#248 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,980 Thanks
  • 4,409 posts
Posted January 25, 2015 - 01:18 PM
Toying around with thinking about................ Mowing the front yard :D . Started the day with making a new clutch spring, I think I'll replace the 1/4" cotter pin (that the spring connects to) with a 1/4" eyelet. I gathered up some more parts for cleaning - sanding - cleaning - and painting, in that order. Tools I use are mouse sander, wire brush, and a small dremel wire brush. I also looked through my wire box to see if I had better wire, not.
Edited by larrybl, January 25, 2015 - 01:19 PM.
  • T Guiles and Gabriel have said thanks
#249 MH81 OFFLINE
Posted January 25, 2015 - 02:20 PM
I think I'm a ways from mowing here. Better hurry up, that grass will start growing again as soon as you hit 40 degrees  :poke:
#250 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,980 Thanks
  • 4,409 posts
Posted January 25, 2015 - 06:08 PM
I broke out RED for some seat time today, also the weed wacker, it started on the first pull after sitting for a couple months. Grass is cut and the deck is blown off and cleaned underneath. Now the shop smells of grass and dog bombs. I installed a spring retainer instead of the 1/4 cotter pin, I think this will work fine. Still waiting on the flat pulley and electrical connectors.
  • Gabriel said thank you
#251 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,980 Thanks
  • 4,409 posts
Posted January 25, 2015 - 07:51 PM
40 deg? We will be in the 70's most of next week with rain next weekend, I'll be back out there sooner than you think :smilewink:
#252 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,980 Thanks
  • 4,409 posts
Posted January 26, 2015 - 10:29 PM
I decided to change gears this week and work on the wiring. Ignition switch looks new, and I know it works from the test start. Before I can mount the rear end and rear plate there is a cross plate that goes above the transmission and has a grommet that the rear PTO connector and rear light wires go through. This has to be installed before the transmission. I still need 16 Ga. Yellow and Orange, and a PTO switch, I should be able to get this all tomorrow. Hope to have the rear end mounted by this weekend.
Edited by larrybl, January 26, 2015 - 10:30 PM.
  • MH81 and T Guiles have said thanks
#253 KennyP ONLINE
  • 38,267 Thanks
  • 45,876 posts
Posted January 27, 2015 - 05:38 AM
This has rear PTO? Need lots of pics of that setup!
#254 TAHOE ONLINE
TAHOE
  • 7,964 Thanks
  • 5,672 posts
Posted January 27, 2015 - 08:40 AM
I think that was for the rear electric actuator for the electric hitch option. These tractors never came with rear PTO. My 16/6 has a swich and wires already for one.
#255 KennyP ONLINE
  • 38,267 Thanks
  • 45,876 posts
Posted January 27, 2015 - 08:55 AM
Thanks. That may explain why I've never seen one!
