Old Girl 1978 Roper
976 replies to this topic
#196 KennyP OFFLINE
  • 40,857 Thanks
  • 47,081 posts
Posted January 06, 2015 - 06:25 AM
I'd be afraid of getting it dirty! Or scratching it!
#197 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,450 Thanks
  • 4,571 posts
Posted January 06, 2015 - 10:13 PM
Oh, she will be used, and Showed if an opportunity come up. Fixen to drive the guy at Fastenal nuts trying to locate Grade 8 Carriage bolts, 3/8-16 X 1 "Short Shoulder". The Short shoulder is the kicker as these go through a square hole in the deck, then a round hole in the deck adjustment bracket. I may try Sears again for these, I got my first shipment of pulleys in from them, I am waiting on the spring I ordered to see if it can also substitute  for the NLA one.
#198 KennyP OFFLINE
  • 40,857 Thanks
  • 47,081 posts
Posted January 07, 2015 - 05:54 AM
Never knew they made Grade 8 Carriage bolts. Those may be hard to find. Have you tried doing a part # search at Sears? They may have a substitute.
  • larrybl said thank you
#199 AfterShock95 OFFLINE
AfterShock95
  • 420 Thanks
  • 365 posts
Posted January 07, 2015 - 11:40 AM
How about dry ice I've taken races out in a big haul truck using dry ice
#200 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,450 Thanks
  • 4,571 posts
Posted January 07, 2015 - 07:42 PM
Sorry, they are grade 5, but short shoulder. I'll search sears after while. at least the mandrels are done, greased, and spin smooth. :thumbs:
#201 MH81 OFFLINE
  • 29,978 Thanks
Posted January 07, 2015 - 08:54 PM
These guys seem to have them. No idea who they are or how they are to buy from, but it appears the bolt does exist.
http://www.fastener-...Bolts-s/418.htm
#202 KennyP OFFLINE
  • 40,857 Thanks
  • 47,081 posts
Posted January 08, 2015 - 05:37 AM
Thanks, Alan. Just had not heard of one before. Thought they were all Grade 5 or less!
#203 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,450 Thanks
  • 4,571 posts
Posted January 08, 2015 - 07:58 PM
I found new blade bolts today, but still haven't cone across the short shoulder carriage bolts (61P) on the diagram. Sears list's them as regular HEX bolts (STD523710). This would probably work, but I think I came up with a better modification of the Gr. 5 carriage bolts I have. If I add a large washer, then the shoulder is to the correct size (still fits the square hole in the deck, and doesn't push up on the brace), and the head and washer still provides a smooth surface underneath.
  • KennyP and Gabriel have said thanks
#204 Dpregs OFFLINE
Dpregs
  • 104 Thanks
  • 138 posts
Posted January 09, 2015 - 09:44 AM
As for the decals, I am using Microsoft Power Point to create the decals, then printing them out with a laser printer on to 8 X 11 sheets of "Chartpak" model DAFPB8L engineering transfers.
Is this the decal stuff you are using?  If so, seems like it is a discontinued item, so get while you can :)
http://www.gsdirect....r-dafpb-8l.html
Edited by Dpregs, January 09, 2015 - 09:44 AM.
#205 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,450 Thanks
  • 4,571 posts
Posted January 09, 2015 - 05:19 PM
Thanks, I am having the Shop I work in order one more box of these.
#206 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,450 Thanks
  • 4,571 posts
Posted January 09, 2015 - 11:24 PM
I received the Idler and Mule pulleys today, and had a good week of locating elusive hardware. There is still one spring that I can't find. I did find a common spring that is the correct length, but one end needs turned to hook in the deck. I practiced turning the ends on a couple trampoline springs I have. I think I can modify the big one to work (What do you think?). I also came up with a hardware sorting solution as I had to buy packs of 10 - 20 on some items. I'm sure these will be used as I move foreword.
#207 MH81 OFFLINE
  • 29,978 Thanks
Posted January 10, 2015 - 01:11 AM
I think you've got the spring licked.
Bet the wife's ticked that she can't find her Tupperware.
  • wvbuzzmaster said thank you
#208 KennyP OFFLINE
  • 40,857 Thanks
  • 47,081 posts
Posted January 10, 2015 - 05:27 AM
Nice sorting containers! Good luck with the spring!
#209 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,450 Thanks
  • 4,571 posts
Posted January 10, 2015 - 06:29 PM
Took a break today, it is 32* and raining and went to a boat show with the Grandson, he will be featured in the local news paper tomorrow.... I'll need to get a few copies. :dancingbanana:
  • MH81, KennyP and Sawdust have said thanks
#210 UncleWillie ONLINE
  • 16,251 Thanks
  • 8,969 posts
Posted January 10, 2015 - 06:33 PM
Looks like he had fun.
