Old Girl 1978 Roper
968 replies to this topic
#1 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,980 Thanks
  • 4,409 posts
Posted November 01, 2014 - 03:53 PM
The "Old Girl" <---, is HOME! What a score!  All the manuals, Snow Blower and tire chains to boot! I have moved Her inside and will start with removing Her deck, and PB Blasting every bolt I can find. Sorry for the over size pictures, I forgot to re-set my camera. The PO said he moved here from Illinois, I guess you need something like this up there. While moving Her into Her place in the shop, She roll's free, and the steering fells tight (no slop). Man, She is bigger than the Ford LGT-145, and I can't believe I scored all the original manuals.
  • rustyoldjunk, MH81, Alc and 16 others have said thanks
#2 Cat385B ONLINE
    HAZMAT CAT
  • 13,969 Thanks
  • 10,001 posts
Posted November 01, 2014 - 04:03 PM
Blue, green, red, and white. Yep, it's a keeper.
  • rustyoldjunk and larrybl have said thanks
#3 KennyP ONLINE
  • 38,270 Thanks
  • 45,877 posts
Posted November 01, 2014 - 04:39 PM
Congrats, Larry! Glad you got some manuals to go with it too!
  • rustyoldjunk, larrybl and tinbender7 have said thanks
#4 rustyoldjunk OFFLINE
rustyoldjunk
    Has anybody seen my coffee ?
  • 2,625 Thanks
  • 1,311 posts
Posted November 01, 2014 - 05:43 PM
That is a great score Larry and on top of everything else it does have the N52 big block that all the Onan guys drool over.
  • larrybl and superaben have said thanks
#5 MNGB ONLINE
MNGB
  • 2,109 Thanks
  • 1,403 posts
Posted November 01, 2014 - 05:47 PM
Hi Larrybl, congrats on your new tractor, when you get it cleaned up and running I'll bet your going to like it. Yep its always nice to get the original manuals even though one can get replacements its a great feeling to have the originals at least to me don't know why but it is.
  • larrybl and jerseyhawg / glenn have said thanks
#6 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,980 Thanks
  • 4,409 posts
Posted November 01, 2014 - 06:20 PM
Deck removed and soaked in PB, Stored for now. It is pretty rusted and the belt cover will need a lot of TLC. The outer mandrills are froze, I pumped them full of grease. I'll come back to this later. Checked the oil, full and clean, Air filter is present but will need replaced, Battery won't take a charge. Looking through the brochures and I will stick with the original colors, not sure about the hub caps. Neighbor said he can help with the decals :dancingbanana:
#7 MH81 OFFLINE
Posted November 01, 2014 - 06:22 PM
Man Larry, I hope you don't mind me coveting your old girl... Great haul with the tractor and with the manuals and the attachments. I've never seen the manual in the lower left. If you ever get a chance to scan it I would love to see it.
  • larrybl and wvbuzzmaster have said thanks
#8 TAHOE ONLINE
TAHOE
  • 7,969 Thanks
  • 5,672 posts
Posted November 01, 2014 - 06:41 PM
Sweet score Larry. Like Alan, I am a little envious also.
If it follows the Sears production, the plastic gas tank under the seat puts it at a 1975.
  • larrybl, MH81 and KennyP have said thanks
#9 EricFromPa ONLINE
EricFromPa
  • 3,649 Thanks
  • 3,109 posts
Posted November 01, 2014 - 06:47 PM
I would Change the Oil now before you try to fire it up.
I just got a Cub Cadet 1440 cyclops that sat for a bit and checked the oil in it.Looked super clean but drained it anyway.I ended up getting about 1/2 a cup of water and dirt out of it.Oil floats on top of water and dirt will settle to the bottom of the water.
I ended up flushing the engine out with Kerosine.and installed a new filter on it.Hey got the tractor for $40 with a bad tranny and busted hood but I now have a good running 14hp Briggs V-Twin vanguard and 4 good tires and rims to put on something.To bad someone robbed the PTO off of it and cut up all the wiring but I'm happy with the parts.
Never trust Oil if it sets for a few years.
That's a nice old Roper and a big old Onan.Should make a heck of a nice tractor when your done with it.
Edited by EricFromPa, November 01, 2014 - 06:49 PM.
  • larrybl said thank you
#10 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,980 Thanks
  • 4,409 posts
Posted November 01, 2014 - 06:49 PM
That is the Brochure.... In Color!
  • DH1, MH81, KennyP and 2 others have said thanks
#11 Bill56 OFFLINE
  • 839 Thanks
  • 2,179 posts
Posted November 01, 2014 - 06:52 PM
Very nice!! Congratulations!
#12 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,980 Thanks
  • 4,409 posts
Posted November 01, 2014 - 06:54 PM
EricfromPA, This will be a frame up restore. I will change the oil, and fire the engine just long enough to see if I need to re-ring or re-build. I lucked out on BMP with it needing only a lite hone. The Craftsman 18hp twins both had to be bored 0.020 over and new pistons, valves, and rings. I'll post a vid once I get to the point of cranking this beast up to see what the next steps will be..
  • EricFromPa, KennyP and tinbender7 have said thanks
#13 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted November 01, 2014 - 07:33 PM
I think you did just fine, Larry!
Ben W.
#14 MH81 OFFLINE
Posted November 01, 2014 - 08:14 PM
Ooooh, color all the way through.
  • wvbuzzmaster said thank you
#15 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,980 Thanks
  • 4,409 posts
Posted November 01, 2014 - 09:33 PM
I am out of PB, and need to pick some up tomorrow. Hood and Grill are removed and separated. All the fasteners are bagged and labeled. Just sitting now studying the construction of the old Girl. They didn't skimp on the metal on this one. Transmission does shift, but sounds a little dry. I may try and source some mufflers and engine gasket kit, carb kit, and fuel pump kit.
  • KennyP and MountainMichael have said thanks
