Poodle Attack
4 replies to this topic
#1 HDWildBill OFFLINE
  • 8,985 Thanks
Posted November 01, 2014 - 10:16 AM
If you haven't heard about the latest hacking method it is called the Poodle attack method.  You can read about it here.  This article tells you what each browser is doing about the issue, and also for you windows users give you a link (at the bottom) to the M$ stopgap tool.
For those who are comfortable with using the about:config settings in FF. You can change your TLS minimum setting to 1. My understanding is that changing that setting will not allow SSL 3.0 to connect.
  • Cvans, boyscout862 and Auburn David have said thanks
#2 KennyP OFFLINE
  • 41,529 Thanks
  • 47,427 posts
Posted November 01, 2014 - 11:00 AM
Where do you find that 'about:config settings' in FF?
#3 glgrumpy OFFLINE
  • 8,849 Thanks
  • 8,036 posts
Posted November 01, 2014 - 12:10 PM
What?     Zis the message like posted above and mine on Yahoo wanting you to re-figure as you have used up your space?
                                                Puter-Dummy here!
#4 HDWildBill OFFLINE
  • 8,985 Thanks
Posted November 01, 2014 - 01:31 PM
Type it in the address line but I warn you be careful. Then just do a search for TLS is should come back with 6 settings then find the Security. TLS.version.min to a 1.  To make the change highlight the setting and then right click and click on Modify.  Change if from a zero to a 1.  Close everything out.
  • KennyP and motobreeder have said thanks
#5 KennyP OFFLINE
  • 41,529 Thanks
  • 47,427 posts
Posted November 01, 2014 - 04:55 PM
Took a bit but it's done. Type in about:config though. Took a bit to get that right. I even went back to recheck and it is on 1.
  • HDWildBill said thank you
