Battery repair ???
81 replies to this topic
#76 tractorguy2 OFFLINE
tractorguy2
  • 8 Thanks
  • 17 posts
Posted November 26, 2013 - 11:44 PM
another good thing is in each cell crush a bayer asprin and put one in each thats crushed did it with 2 batteries that would other wise be bad or have a short
Sent from my LG-P769 using Tapatalk
  • HDWildBill said thank you
#77 victor3ranger OFFLINE
victor3ranger
  • 314 Thanks
  • 630 posts
Posted November 27, 2013 - 09:31 AM
Would you use the bayer asprin with the epsom salt solution??
I have used the epsom salt solution on a hand full of batteries so far and it really does seem to bring some of them back to life.
I also found out that the SO-CALLED maintance free sealed batteries really are not truely sealed, they can be redone just like a regular battery :thumbs:
#78 tractorguy2 OFFLINE
tractorguy2
  • 8 Thanks
  • 17 posts
Posted November 27, 2013 - 06:48 PM
[quote name="victor3ranger" post="388158" timestamp="1385562675"]Would you use the bayer asprin with the epsom salt solution??
I also found out that the SO-CALLED maintance free sealed batteries really are not truely sealed, they can be redone just like a regular battery :thumbs: sure
#79 Gtractor ONLINE
Gtractor
    G-agressive tractor
  • 9,122 Thanks
  • 4,888 posts
Posted December 12, 2013 - 08:31 PM
I recently had another battery fail and wanted to give an update.  I think you will like it!
In June 2012 I came back from a checkup with my cancer Doctor in Kansas.  For trips, I take our econobox which is a 1991 Ford Escort.  That evening when I pulled in the carport I turned on the map light to check the mail.  I forgot to turn the map light off that evening.  :(   Six weeks later, the next time I went to use the car,  the battery was totally dead.   I put the trickle charger on and left it 24 hours.  Since then - mind you its been a year and a half - it turned the engine over slowly.  A week ago when it got really cold the battery was too weak to start the engine.  I believe if it was warm it would still have enough juice, just not in this cold.
I took a nearly new battery out of one of the pickups I seldom use stuck it in the Escort because it is our backup car and it has to be ready all the time - the pickup, not so much.
After removing the old battery from the Escort I saw it had the reciept in the pouch on the side for a warranty date verification.   After chipping the ice in the pouch enough to remove the reciept,  I took it in the house to thaw so I could unfold it hoping to read the date.
I BOUGHT THAT BATTERY ON JULY 19TH 2000!!!!
More than 13 years out of a battery that sits for long periods of time in a seldom used car - and that I know set totally dead for six weeks.   Convinced the epsom salts had a hand in it lasting so long.   Just wanted to share.
  • Texas Deere and Horse, sacsr, Cvans and 1 other said thanks
#80 Fleetman OFFLINE
Fleetman
  • 22 Thanks
  • 14 posts
Posted May 15, 2014 - 11:50 AM
One thing that can also help with a dead battery is to roll it over a few times, reinstall, and then recharge.  It sort of "cleans" the plates off and allows the cells to take a charge again.  I've had luck with this method a few times.  I like the idea of Epsom salts and will try it myself once I come across a dead battery again.
  • shorty said thank you
#81 John Arsenault ONLINE
John Arsenault
  • 2,403 Thanks
  • 1,158 posts
Posted June 24, 2017 - 06:37 AM
I have Epson Salt in every battery I own except one. It really does make them last longer and will fix some that have already died. I just pour the Epson in - in granular form and shook the batteries good. The battery that is currently in my daily driver pickup died four years ago. It wouldn't crank the engine over until I put the Epson in and it is still going today. This winter it started getting weak again but I got four free years out of it! As of now, if its below about 15 degrees my pickup won't start due to the weak battery but I have other vehicles I can drive if I need to go. I don't have to go anywhere most days - its not like I have a job - so I'm going to allow that battery to run its course. An old timer in our local tractor club told me about the Epson battery "additive" many years ago and I can tell you it does work. The only reason I haven't used it recently is the only battery I have that went bad has been under warranty and I have had five free batteries in the last three years thanks to wally world. They used to have the best batteries - now they pedal total junk.
I know this is an old post and I picked it up from a new one today....but great read......This past winter my sons car would not start so we pulled out the battery because it was only a few months old and headed to the parts store for a replacement. As I am standing at the counter with the battery on it I noticed the sides are a bit swelled, and now a frosty layer is forming around it. At that point I pick up the battery and shake it.....Its frozen solid
  • Gtractor said thank you
#82 shorty ONLINE
shorty
  • 5,287 Thanks
  • 5,169 posts
Posted January 16, 2018 - 10:39 AM
Old thread I know. I had a battery start refusing to take a charge this winter. Going to give this a try. Nothing to lose and whether it works on this one or not. I will have given it a try and gotten the experience. If it works I have more that are about at the failing point.
