Battery repair ???
81 replies to this topic
#61 HDWildBill OFFLINE
  • 8,984 Thanks
Posted February 04, 2013 - 01:04 PM
If I would near boil the water,dissolve the epsom salt, put in old milk jugs
could you store the solution without it crystallizing?
I keep some made up in an old plastic coffee container.
Well I've got 2 large deep cycles that  I got for free,  going to try it, got nothing to lose, looks for some batteries for the h14xl electric  conversion. What does a cell tester look like?
That's the way I look at it, if the battery is already causing problems then what do you have to lose.  We only got another 2 months or so out of the wife's battery but there are still a few GT's around the county with batteries that have had the treatment.
#62 Jehtro OFFLINE
Jehtro
  • 109 Thanks
  • 276 posts
Posted February 04, 2013 - 01:17 PM
Ya I'm just going to try it, Even if i could just get them working enough to test the tractor a bit,
I've got 1 lawn tractor battery under the bench that junk, it will probably get some juice too!
#63 robert_p43 OFFLINE
robert_p43
  • 572 Thanks
  • 534 posts
Posted February 20, 2013 - 04:42 PM
Seems like the thing to do would be to keep a bottle of this magic water around, and whenever you would add water to a battery, from the time it is new, to use this water instead.  Why doesn't somebody bottle up epsom salts and water to sell at auto parts stores?
#64 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted February 21, 2013 - 08:37 AM
Here's a picture of one:
And link: http://en.wikipedia....wiki/Hydrometer
I haven't used my in years.
#65 Sundowner OFFLINE
Sundowner
  • 1 Thanks
  • 3 posts
Posted June 04, 2013 - 01:41 PM
After reading all the comments I am confused. My understanding is that you add the epson salt medium to the existing electrolyte. You do not drain out the electrolyte is that correct?
#66 Texas Deere and Horse OFFLINE
  • 14,888 Thanks
  • 15,514 posts
Posted June 04, 2013 - 02:27 PM
First off Sundowner, Welcome to GTtalk, glad you joined us here.
You want to mix the salt up in distilled water, I usually do it on the stove to help dissolve the salt. Then I take out some of the electrolyte out of each cell so I can add back the salt water solution. I hope that makes sense.
  • HDWildBill said thank you
#67 HDWildBill OFFLINE
  • 8,984 Thanks
Posted June 04, 2013 - 04:24 PM
Welcome Sundowner.  Like Brian, I mix up a solution of Epsom salts and distilled water and then if the cell's of the batter are full I will use a bulb and take some battery solution out of each cell and put it with the Epsom Salts solution.  The I will go back and fill each cell to the proper level and put it on a battery tender until I get a green light.  If a cell is down I will just put the Epsom Salt solution in that cell straight.  There are still quite a few batteries I have done this too that are still in service.
  • Texas Deere and Horse and sacsr have said thanks
#68 Sundowner OFFLINE
Sundowner
  • 1 Thanks
  • 3 posts
Posted June 05, 2013 - 10:17 AM
Thanks for the info. I have 3 8D's from my boat and going to try it. Nothing to lose.
#69 Texas Deere and Horse OFFLINE
  • 14,888 Thanks
  • 15,514 posts
Posted June 05, 2013 - 10:46 AM
Sometimes you have to cycle the battery's to get them back up and holding a good charge.
In case you don't know what I mean, charge the battery up as much as it will take, then use a 12vt light or something to run the battery back down to about dead, then re-charge the battery again and if it's going to be good, it will take a better charge each time you cycle it.
Good Luck and be sure to report back how it goes for you. :thumbs:
  • powerking56 and HDWildBill have said thanks
#70 HDWildBill OFFLINE
  • 8,984 Thanks
Posted June 05, 2013 - 01:18 PM
Thanks for bring up the cycling Brian.  I had forgotten about that aspect of getting a battery back up to speed. :thumbs:
#71 boyscout862 ONLINE
  • 13,551 Thanks
  • 9,427 posts
Posted June 07, 2013 - 06:58 AM
Thanks for the info guys. I'll try this on a couple that I have. Should it be a fast charge? Rick
#72 Texas Deere and Horse OFFLINE
  • 14,888 Thanks
  • 15,514 posts
Posted June 07, 2013 - 02:25 PM
Rick, I usually do an 2Amp over night charge on them. Sometimes I put them on highest setting on the charger to wake them up, then turn it back down.
#73 HDWildBill OFFLINE
  • 8,984 Thanks
Posted June 07, 2013 - 04:43 PM
Rick, I just use a battery tender, same type I use on the MC.  Like Brian, I just let it sit over night and usually in morning I will have a green light.  Although I have had a couple that gave me a blinking amber light which means they are ready to be used as a turn in for a new one.  But I figure it is worth trying.
  • Texas Deere and Horse and boyscout862 have said thanks
#74 Sundowner OFFLINE
Sundowner
  • 1 Thanks
  • 3 posts
Posted June 08, 2013 - 10:25 AM
My first try on the 8D battery doesn't look promising. Bass surface charge after being on the 2 amp charger over night. Dropped off pretty quick. Will try discharging it then charge again. Considering changing the electrolyte if that doesn't work. Has anyone done that?
#75 Texas Deere and Horse OFFLINE
  • 14,888 Thanks
  • 15,514 posts
Posted June 08, 2013 - 01:19 PM
I would try removing more electrolyte and replacing with more salt solution. It may take a couple days on the charger to get it going if you can save it at all.
