Getting The Lawnmaster Back To A Driving Tractor.
3 replies to this topic
#1 rustyoldjunk OFFLINE
    Has anybody seen my coffee ?
  • 2,643 Thanks
  • 1,318 posts
Posted October 31, 2014 - 10:00 PM
Well at least that's the plan. I pulled the original 6 hp Briggs off and put it on the bench to clean the points,coil ( I may change coils,the points wire broke off it and I have nice replacements.),the fuel system and the recoil up. The engine and carb is all free so I am hoping for a runner when I get it back together. I am going to try to get the front axle welded back together next week. Once back together I am hoping for a decent running driving old tractor. The steering was frozen up but came loose easily. I won't have the sheet metal but it will still be a cool little 50 year old tractor to pull the recoil on the original engine,get on and putt around. If everything else goes well I may or may not look for sheet metal. To tell you the truth I am really liking the very simple,very basic looks of the "naked" 50 year old tractor. It is so simple and everything is so easy to get to and work on. Just a fun little project. Here are the pulled apart pictures. Interestingly enough,after sinking into the ground for decades the deck spindles and still free and smooth. I do have the hood also but it is in bad shape on the bottom front. I just plan to put it back together at this point and hopefully use it to putt around on or pull a trailer,etc. It if works out well I may pull it back apart later and give it a good cleaning for a little paint.
Edited by rustyoldjunk, October 31, 2014 - 10:23 PM.
  • Alc, GTTinkerer, superaben and 1 other said thanks
#2 Alc ONLINE
  • 7,012 Thanks
  • 7,494 posts
Posted November 01, 2014 - 06:26 AM
Should be a fun little tractor when your done :thumbs:  What happened to the front axle ?
#3 KennyP ONLINE
  • 38,998 Thanks
  • 46,242 posts
Posted November 01, 2014 - 07:22 AM
Good luck with the resurrection!
#4 motobreeder OFFLINE
  • 433 Thanks
  • 618 posts
Posted November 01, 2014 - 03:11 PM
I have a later model Moto-mower that works great as a little tug for pulling a wagon around the yard.
