Massey/ Snapper 1Xxx Series Third Aux Valve
28 replies to this topic
#16 limebuzz OFFLINE
limebuzz
  • 1155 Thanks
  • 1083 posts
Posted May 18, 2015 - 08:54 AM
All I did when I added a spool was took one off a spare I had. Just needed 3 longer bolts and your good to go.
  • ENafziger said thank you
#17 Dayton_King OFFLINE
Dayton_King
  • 1807 Thanks
  • 1286 posts
Posted May 18, 2015 - 11:11 AM
So in theory I need to buy another set and hook em all up. I am thinking about adding a port to the back for a wood splitter
#18 limebuzz OFFLINE
limebuzz
  • 1155 Thanks
  • 1083 posts
Posted May 18, 2015 - 11:20 AM
Yes, that's all ou have to do. Take the outer cap off and add a spool,then bolt your end cap back on. Don't forget your plastic washers in-between your new spool.
#19 Dayton_King OFFLINE
Dayton_King
  • 1807 Thanks
  • 1286 posts
Posted May 18, 2015 - 07:16 PM
Is there a place where I can buy 2 valves that are bolt on?
#20 KennyP ONLINE
  • 51020 Thanks
  • 52655 posts
Posted May 18, 2015 - 07:51 PM
Sounds like the same valves the FF's have.
#21 limebuzz OFFLINE
limebuzz
  • 1155 Thanks
  • 1083 posts
Posted May 18, 2015 - 08:17 PM
Dayton_King,Maybe check with Joe's Outdoor. He is a site sponsor here.
Kenny, they very well could be. Never seen a FF before yours.
#22 TUDOR OFFLINE
TUDOR
  • 573 Thanks
  • 507 posts
Posted May 19, 2015 - 02:37 PM
Most GT's use the same valve sets for implement lifts. Ditto most GT loaders.
You won't be running a log splitter off of that system with any satisfaction. The flow rate is 3 gpm at WOT and  the max rated pressure from the charge pump is 1000 psi. Neither is realistic for a log splitter.
In effect, you have to run your 18 hp engine at max to do 2 hp worth of work.
Check on ebay for a replacement valve set. They do show up periodically.
Edited by TUDOR, May 20, 2015 - 04:34 AM.
  • limebuzz said thank you
#23 Dayton_King OFFLINE
Dayton_King
  • 1807 Thanks
  • 1286 posts
Posted May 19, 2015 - 07:34 PM
Thanks Tudor it was a novel thought
#24 1kubotakid OFFLINE
1kubotakid
  • 1 posts
Posted May 29, 2015 - 11:01 PM
Bob,
I recently up graded my 1655 to a 3 spool valve bank. I cant figure out why the 3pt valve dosn;t
have the float option from the factory? Anyway I restacked tham so the first 2 have the float valves,
now I have a float option for my 3pt and my front blade. Is there any good reason that the factory
didn't allow the 3pt to float? When I use a rear blade OR a landscape rake I NEED it to float, Whem Iam groming. Whats your experience? using the 3pt without a float valve?
Thanks Bob
Eric
#25 KennyP ONLINE
  • 51020 Thanks
  • 52655 posts
Posted May 30, 2015 - 06:04 AM
Here's a pic of the valves in the Sears FF tractors.
I'd like to get 2 of the single valves to add to my FF's. Or even one double!
#26 olcowhand OFFLINE
  • 44102 Thanks
  • 32301 posts
Posted May 30, 2015 - 06:21 AM
Bob,
Thanks Bob
Eric
The 50 & 55 series don't need a float valve because the design of the 3 point system itself has a built in float system.  Once you put your implement down to the desired depth, the lift arms will still allow themselves to lift to max lift position.
  • limebuzz and ENafziger have said thanks
#27 TUDOR OFFLINE
TUDOR
  • 573 Thanks
  • 507 posts
Posted May 30, 2015 - 06:52 AM
:ditto:
Gravity to lower, pressure to raise.
#28 ENafziger OFFLINE
ENafziger
  • 261 Thanks
  • 254 posts
Posted May 30, 2015 - 11:13 PM
What does the "detent adjusting screw" do?
#29 TUDOR OFFLINE
TUDOR
  • 573 Thanks
  • 507 posts
Posted May 31, 2015 - 01:17 AM
It adjusts the spring pressure on the ball when it's in the spool detent groove. Over time, the edges of the groove will wear allowing the spool to spring back to neutral due to vibration if the ball isn't snugged down. Too tight and it will be difficult to release from the float position.
Edited by TUDOR, May 31, 2015 - 01:18 AM.
  • KennyP and ENafziger have said thanks
