Help! Something Went Wrong Today
engine starter no start crank
19 replies to this topic
#1 aevansgatech OFFLINE
aevansgatech
  • 213 Thanks
  • 261 posts
Posted October 31, 2014 - 05:27 PM
I'm hoping you guys can help me identify what happened today. It's the first day near 32F here in Michigan, so I figured I'd fire up my '91 Ford YT 16H (16hp B&S) and see how it did in the cold. Well, it started alright and for about 10-15 minutes I was playing with different choke/fuel positions to see what would give me a strong startup and not lose power.
I'm guessing I cycled the ignition 30 times total playing around with it. Then suddenly after one, it completely stopped responding. I get no crank action whatsoever. I know the battery is ok because when I turn the key I can turn the lights on.
My question is what could I have possibly done to the starter/ignition/etc to kill it? I'm hoping after it rests awhile I'll be able to start it up.
Thoughts!?
I'm now very worried about how it will perform in sub-zero temps this winter
#2 farmerall OFFLINE
farmerall
  • 2,202 Thanks
  • 1,473 posts
Posted October 31, 2014 - 05:30 PM
The first think I would check are the fuses. One could have went bad and that would cause the starter not to work.
  • hamman said thank you
#3 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted October 31, 2014 - 05:36 PM
Probably a fuse like Farmerall said,or you could have over heated the starter...if it has thermal protection it wont work till it cools off.
#4 Bill 76 ONLINE
Bill 76
  • 1,892 Thanks
  • 1,177 posts
Posted October 31, 2014 - 05:51 PM
What they said check for a fuse.Does it have a solnoid in the starting circuit if so try jumping across the starter terminals
#5 aevansgatech OFFLINE
aevansgatech
  • 213 Thanks
  • 261 posts
Posted October 31, 2014 - 06:03 PM
Thanks for the fast replies everyone! I'll give it some time to cool and see if it was overheating.
If it's still not starting I'll start looking into the fuses. Thanks!
#6 KennyP OFFLINE
  • 37,422 Thanks
  • 45,461 posts
Posted October 31, 2014 - 06:07 PM
Are you sure the battery isn't dead? All that starting in such a short time can kill lots of things!
#7 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Thats a good suggestion,could be the solenoid for sure.
#8 toomanytoys84 ONLINE
toomanytoys84
    Aaron
  • 9,632 Thanks
  • 5,834 posts
Posted October 31, 2014 - 07:01 PM
My vote would be the solenoid got hot and is now stuck in the open position.
Bang it with a screwdriver handle or hammer handle. Not like you are trying to break it. More like a thump.
  • Bill 76 said thank you
#9 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted October 31, 2014 - 07:19 PM
Its never a good Idea to cycle the ignition 30 times  playing around with it. :(
  • Bill 76, Tim Bergfeld and aevansgatech have said thanks
#10 aevansgatech OFFLINE
aevansgatech
  • 213 Thanks
  • 261 posts
Posted November 01, 2014 - 12:58 AM
Yeah I got a little overzealous, but it kept slowly dying on me.
In any case it still won't start after sitting for 1hr, so looks like I'll be trying the gentle starter banging and checking the fuses/solenoid this weekend.
That's alright, this project just got more interesting!
  • Auburn David said thank you
#11 GTTinkerer OFFLINE
GTTinkerer
    GT Tinkerer
  • 1,162 Thanks
  • 1,331 posts
Posted November 01, 2014 - 01:30 PM
Hey hold on there, you are taking money out of some technician's pocket.
  • Gabriel and Auburn David have said thanks
#12 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted November 01, 2014 - 01:35 PM
Your right!!!my bad...crank away!!! :rocker2:
  • Gabriel said thank you
#13 aevansgatech OFFLINE
aevansgatech
  • 213 Thanks
  • 261 posts
Posted November 01, 2014 - 04:26 PM
Alright guys.. let's not get carried away. I purchased the GT to do everything myself and learn!  :smilewink:
So I first pulled out the 25-amp main fuse and it was fine. From there I found something quite obvious. My parking brake had come unlatched, so the system interlocks wouldn't allow the engine to start. I noticed it today, but I'm still quite certain that wasn't the issue yesterday.
In any case, I did bang on the starter with a wrench a couple times, and now it's firing up!
Thanks for the responses. I may be catching up on some of this basic engine stuff, but it sure is enjoyable to work on it.  :thumbs:
  • GTTinkerer, Gabriel and Auburn David have said thanks
#14 GTTinkerer OFFLINE
GTTinkerer
    GT Tinkerer
  • 1,162 Thanks
  • 1,331 posts
Posted November 01, 2014 - 08:48 PM
Just jerking your chain a bit.
As far as the enjoyable part after 51+ years of "turning wrenches" the enjoyable part has pretty much petered out.
  • aevansgatech said thank you
#15 olcowhand ONLINE
  • 40,349 Thanks
  • 31,170 posts
Posted November 01, 2014 - 08:54 PM
If it does this again and whacking the starter gets it turning over, then likely the starter brushes are burned down too far and you'll either need a brush kit for it, or simply replace the whole starter.
Also tagged with one or more of these keywords: engine, starter, no start, crank
