Case 446
10 replies to this topic
#1 JoshBrown OFFLINE
JoshBrown
  • 20 Thanks
  • 277 posts
Posted February 20, 2011 - 02:15 PM
Well I got a new tractor its a Case 446.
I also got a rear tiller with the extension (I think it's 42" wide I haven't measured it yet).
I also got a 10" Brinley plow.
I also got a fully adjustable rear grader blade.
I also got a little single gang disk.
I also got a 42" deck that sounds pretty quiet.
I got an extra set of factory rear wheels and tires and weights probably weigh 65# a piece.
I also got a set of bigger wheels and tires 29x12.00x15r that were on it when I got it and another set of just tires same size (no rims). I had to switch back to original wheels on tractor so I could plow. I also need to make a set of spacers for these bigger tires because they were rubbing the fenders a little.
I also got a parts tractor with good rear gears, good axles, good brake assembly, good hyd pump, good travel control valve, good mower hyd lift cylinder, good steering gears and several other odd parts.
The tractor overall is in pretty good shape and all the implements are in great working order. The tractor is surging (idling rough) but reved up runs smooth. Also everything works on the tractor. It just has a lot of oil and grease and such on it (everywhere). I am going to go through it soon and check for leaks ect. and clean everything up. But it is in working order. I plowed my garden today.
It took a few passes to get the plow adjusted right but got it plowing good. Also I haven't loaded my tires yet or put the weights on yet and it still did pretty good. I had to keep one hand on 3 point lift control and when tires started to slip bump it up. But I was really surprised how good it did. I bet it will really plow good when i get the weights on and fluid in the tires.
#2 Reverend Blair OFFLINE
Reverend Blair
  • 501 Thanks
  • 952 posts
Posted February 20, 2011 - 02:36 PM
Nice. Fut a FEL on there and it'll be the perfect all 'round machine.
#3 JoshBrown OFFLINE
JoshBrown
  • 20 Thanks
  • 277 posts
Posted February 20, 2011 - 02:41 PM
I really want to I might try to put one on it next winter. That way I will have time to find some deals on supplies.
#4 daytime dave OFFLINE
  • 4,495 Thanks
  • 6,359 posts
Josh
You sure ended up with a great garden tractor there! You have a great start without having to find attachments here and there. Looks like it plowed great. A FEL, a snow blower and a cab would round out your perfect find.
Keep us posted. Great pics!
#5 nra1ifer OFFLINE
nra1ifer
  • 670 Thanks
  • 1,530 posts
Posted February 20, 2011 - 02:44 PM
Nice! Always good to turn some dirt!
#6 mjodrey OFFLINE
  • 2,345 Thanks
Posted February 20, 2011 - 03:25 PM
Very nice 446.
#7 Bill56 OFFLINE
  • 839 Thanks
  • 2,179 posts
Posted February 20, 2011 - 03:37 PM
You definitely bought a nice set-up Josh. Congratulations and thanks for sharing all the pictures.
#8 olcowhand ONLINE
  • 36,180 Thanks
  • 29,972 posts
Posted February 20, 2011 - 04:00 PM
You sure didn't waste any time putting her to work Josh! Yep, a good tractor, just needs some minor attention. I knew you'd like it! And already turned some soil.
I bet everyone living near you gets their garden plowed free.....even if they don't want a garden! :bigrofl:
#9 JoshBrown OFFLINE
JoshBrown
  • 20 Thanks
  • 277 posts
Posted February 20, 2011 - 06:49 PM
Yeah I would probably help them out lol.
#10 wvbuzzmaster OFFLINE
  • 4,496 Thanks
  • 7,343 posts
Posted February 20, 2011 - 07:14 PM
Nice tractor Josh. I guess this either means you don't need my 444 or want it even more lol.
#11 Texas Deere and Horse OFFLINE
  • 14,466 Thanks
  • 15,392 posts
Posted February 20, 2011 - 07:25 PM
Josh, I so glad you found a tractor and all the stuff you needed to get you going. Great deal.
