Need Help Deciding Which To Get - Box Blade Or Rear Blade
8 replies to this topic
#1 lyall ONLINE
lyall
  • 1,901 Thanks
  • 1,476 posts
Posted October 27, 2014 - 07:55 PM
I am looking a getting a box blade or a rear blade
I will be using it on my JD 212 or 214
Brinly-Hardy Box Scraper — 38in. Working Width, Model# BS-38BH
at Northern Tool is $189.99
Brinly-Hardy Rear Blade Attachment — 42in.W, Model# BB-562BH
at Northern Tool is $199.99
I do have a long gravel driveway and parking area
Which would work the best on a gravel driveway?
I would be also using in the garden to help level the compost I am going to be putting on it.
Would like to know which one one have and how you like it
Thanks
Glen
#2 DH1 ONLINE
DH1
    Electric Tractors
  • 5,009 Thanks
  • 5,462 posts
Posted October 27, 2014 - 07:59 PM
Box blade.
I have both and the box blade works better faster and does a neater job.
Go over it with the teeth down first then with the teeth up to finish and smooth it out nice. I find after a rain is the best time to do it, driveway is softer.
  • lyall and boyscout862 have said thanks
#3 GTTinkerer OFFLINE
GTTinkerer
    GT Tinkerer
  • 1,162 Thanks
  • 1,331 posts
Posted October 27, 2014 - 08:05 PM
I used to have a Brinly box blade and the "wings" on the end of the came off and it could be used as a back blade.  The scarifier bar rotated up out of the way but it did not have the mount on the back of the blade for the cement block.  I just hung a 42 pound John Deere weight off each end of the blade.
  • lyall said thank you
#4 propane1 ONLINE
propane1
  • 7,756 Thanks
  • 3,796 posts
Box blade. Better at filling in holes. Noel.
#5 KennyP ONLINE
  • 34,244 Thanks
  • 43,366 posts
Posted October 27, 2014 - 08:11 PM
For the rear of a tractor, I prefer a good box blade. Couldn't find one I liked, so I built one to my specs!
#6 MH81 ONLINE
  • 29,923 Thanks
  • 29,745 posts
Posted October 27, 2014 - 10:26 PM
Best of both worlds, buy the blade and make the end caps and scarifier.
They used to make a 42" box blade but the newer units probably don't have the umpf to pull it.
  • lyall and JDBrian have said thanks
#7 JDBrian OFFLINE
  • 9,596 Thanks
Posted October 28, 2014 - 05:23 AM
Have the Brinly 38" box blade. If 38" will cover the rear of a 214 I would go with that. A box blade is much better IME for general purpose work. If you are handy you can do as Alan says above and build up a box blade from a rear blade that is wide enough to cover your rear tires.
#8 BTS ONLINE
BTS
    Make Stuff Up
  • 3,748 Thanks
  • 2,206 posts
Posted October 29, 2014 - 08:03 AM
I have a 4' box blade on my 20hp Kubota, it works really good but I'm missing the teeth  :ah_shoot: , I haven't really used a blade but I know the box blade is better for filling holes and ect. I also have 2 wheel weights hanging off the back = 200lbs, it works a LOT better now :thumbs:.
I do have a 40" blade that I'm going to use on my Bolens HT23, but I haven't gotten a 3'pt set up on it yet so I can't use it :(.
Good luck
#9 lyall ONLINE
lyall
  • 1,901 Thanks
  • 1,476 posts
Posted October 30, 2014 - 05:07 PM
Thanks All
would like to find a box blade close to me
time will tell - do not want to buy a new one at this time
